03-20-2007, 11:35 AM   #1
"A" setting in camera and aperture rings
Just curious as to what everybody does with lenses that have the aperture ring. Do you use the camera and make adjustments or do you activate the aperture ring setting in the camera and use the ring on the lens instead? Is one better than the next? Any pro's or cons for doing either?
03-20-2007, 11:39 AM   #2
hmmmm, If I don't have the aperture setting on 'A', I:
-Can't use Av/Tv/other modes (have to use manual)
-Can't use Matrix metering
-Can't use P-TTL flash
-Aperture value not stored in EXIF info
About the ONLY advantage I could think of is if you have the D or DS, an external flash (such as the Sigma EF-500), setting an aperture on the lens allows you to use the flash in TTL mode instead of P-TTL.
Oh, to answer the first question, I always leave it on 'A'
03-20-2007, 11:39 AM   #3
Alvin's Avatar
I'm still a rookie when it comes to going full Manual. Especially when it comes to tricky lighting situations. So whenever I'm in doubt, I flip the aperture into A and use the camera in P mode. I take a couple shots, look at the exif on the camera, then flip it to the aperture I want and go from there in M mode on the camera.
03-20-2007, 11:43 AM   #4
Alvin's Avatar
QuoteOriginally posted by egordon99 Quote
You can use your lens wide open in Av mode. The camera will adjust the shutter.
IIRC, in Av mode, you can also stop down your lens to your desired aperture, push the AE-L button, and the camera will stop down, and adjust the shutter for the right exposure, then you are ready to shoot.
03-20-2007, 11:54 AM   #5
But why not just keep the lens on 'A', and set the desired aperture from the body? Not sure why you need to bother messing with the aperture ring, unless you have a COMPELLING reason to do so (forcing TTL flash on a D or DS)
QuoteOriginally posted by Alvin Quote
03-20-2007, 11:56 AM   #6
Yep, if you want to stay WIDE-OPEN, you can use Av mode and set the aperture on the maximum aperture. But I believe that in Av mode, when you go to take the picture, the lens will actually remain wide open (ie will not stop-down to the selected aperture). I'll have to double check this tonight on my DS.
03-20-2007, 11:57 AM   #7
Finn's Avatar
The beauty of a lens with an "A" setting is that you can use it in Av, Tv, or P mode. Otherwise you have to use stopped-down metering with the AE-L button, which is easy once you get the hang of it, but why do it if you don't have to? For my A lenses I always adjust the aperture with the camera body and keep it set to Av. Besides, that way the aperture you are using shows up a) in the viewfinder and b) in the EXIF data.
03-20-2007, 12:22 PM   #8
Alvin's Avatar
I have some SMC M and old K glass, so using the aperture ring gives me some practice Just me, I guess.
03-20-2007, 01:46 PM   #9
It really is a pleasure to use the aperture ring on non-crippled Pentax bodies. Using on-camera aperture adjutment works just fine, but it's definitely not as good or as easy as being able to adjust the aperture via the ring, like on the PZ-1.
03-20-2007, 04:39 PM   #10
Dana G's Avatar
Well, all I can say is that I never had an autoexposure camera until the late 1990's, and I wasn't all that impressed.
I used my MX cameras until I went digital with the D, and now the K10D. But it mostly gets used in a studio with strobe, so the camera's meter doesn't get that much use.
I did test an old M lens with the K10D, shooting RAW, and found it usable but not perfect. I think I'll just keep the Sekonic around for now!
03-20-2007, 06:08 PM   #11
Yep, I was correct. On my DS with Tamron 28-75mm f/2.8. ISO3200, Av mode with aperture ring on 'A', f/2.8 set via the body gave me 1/100. Changed the aperture ring to 2.8 on the lens. Meter still gave me 1/100. Moved the ring to smaller apertures, I still got 1/100s on all apertures. Pressing the AE-L button did NOT stop down the lens (like it would in M-mode) to take a new meter reading. All shots were "properly" exposed using f/2.8 (ie the lens did not stop down to the selected aperture during exposure) regardless of where the aperture ring was.
So unless you want to shoot wide open, Av mode is useless when using the aperture ring. You want to use M-mode.
03-20-2007, 11:49 PM   #12
skaktuss's Avatar
Yesterday I tested my Tefnon (never heard of that before) lens with A setting.
When i set aperture ring to A, Av sets exposure to 0.3"@F4, but when i turned the ring to 4 and pressed AE-L in manual mode, I could shoot at 1/4s. How to explain that?
03-21-2007, 12:14 AM   #13
Mike Cash's Avatar
QuoteOriginally posted by skaktuss Quote
0.3 seconds and 0.25 (1/4) seconds aren't so far apart.
03-22-2007, 08:57 AM   #14
Thanks all for the replies. All good information!
aperture, camera, k-mount, pentax lens, slr lens
What does "Automatic Aperture Setting" mean? Todd Adamson Troubleshooting and Beginner Help 6 10-22-2010 02:29 PM
"A" lenses setting on DSLR Dudley Troubleshooting and Beginner Help 4 10-17-2010 03:17 PM
Is Pentax the only brand with an "A" setting on its lenses? deadwolfbones Pentax SLR Lens Discussion 14 06-12-2009 03:02 PM
540fgz "A" setting question... leadbelly Pentax Camera and Field Accessories 1 09-13-2008 05:23 AM
Pentax K10D ISO setting "on the fly" tohcp Pentax DSLR Discussion 6 07-15-2007 06:23 AM
All times are GMT -7. The time now is 09:08 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
