01-18-2009, 12:27 AM   #16
sharko's Avatar
Usually a polarizer on my lenses during bright daylight. Not only for the polarizing effects but it also acts as a bit of a neutral density filter so I can have more depth of field control with my faster glass.
01-18-2009, 01:45 AM   #17
pop4's Avatar
Hoya HMC UV(n) filters on Sigma 17-70 and 10-20
Minolta AC 1B Skylight filter on my FA35/2
B&W ES 010 UV filter on my F50/1.7
01-18-2009, 02:34 AM   #18
I've had a Hoya HMC UV(0) filter for DA 70 and DA 40 and since I couldn't find 43 mm Hoya, a cheapish Dörr UV for DA21... been wondering though are these really necessary, 'cause pancakes have very good lens hoods which, I think, do offer protection, too. When I bought my first DSLR I was told that UV filters are a good and cheap way to protect your valuable lenses from scratches and have used them ever since, but now I have started to question their value... I haven't done any IQ tests with/without filters, but perhaps I should. Does anyone else use filters with pancakes?
Regards,
Jari
01-18-2009, 04:12 AM   #19
Class A's Avatar
QuoteOriginally posted by JRock Quote
What are the benefits of sky and haze filters?
Haze filters have a slight yellow cast (to counteract the bluish cast caused by haze).
Skylight filters have a slight pink cast (for a warming effect in order to reduce overly dark blue skies)
UV filters are neutral in the visible colour range. The other two above often reduce UV as well.
None of these are required for digital cameras really. You can achieve the effect of the first two with PP and digital sensor are much less sensitive to UV than film is.
Many (myself included) use UV filters for protection. But, you can get pure protection filters (without a UV filter function) as well. I suggest to buy premium multi-coated filters only.
01-18-2009, 04:54 AM   #20
None...
Lens designs are improving rapidly and lenses are so cheap that if any were damaged by a lack of filter, I'd just remind myself to be more careful, replace the lens with a better one, and move on.
BTW: I'm very conscientious... almost over protective. I've never discarded or replaced a lens for any reason.
01-18-2009, 06:19 AM   #21
B+W UV MRC filters on all the lenses, right from the start.
01-18-2009, 09:24 AM   #22
Wheatfield's Avatar
My lenses go naked before the world unless I need to filter them for a specific reason. I've managed 4 decades of photography without damaging a lens that a filter would have prevented from happening.
01-18-2009, 02:29 PM   #23
Just a sun shade
01-18-2009, 02:43 PM   #24
heliphoto's Avatar
And I went two months of DSLR ownership before damaging a lens in a manner which would have been prevented by a filter .
I suppose if you know you tend to get a little fired up and throw caution to the wind like I know I do, you ought to prepare your gear to protect it from your future carelessness, but if you can act with due caution like Wheatfield, you can forgo the protection of a "protection filter".
01-18-2009, 04:21 PM   #25
Wheatfield's Avatar
QuoteOriginally posted by heliphoto Quote
I don't think due caution enters into it. Any equipment I've damaged has been so thorough that the equipment is a complete loss.
01-24-2009, 04:41 PM   #26
The only filters I ever use (and it's a rarity) are a polarizer and a 6X Cross (star) filters. Typically it's just a lens hood and to cap the lens when I'm done!
01-24-2009, 05:39 PM   #27
starting to use colour filters for B&W film
01-24-2009, 06:13 PM   #28
nostatic's Avatar
That'll buff right out...
B+W UV MRC on all my lenses (except for one that has just the regular UV). I have ended up in the desert in windy conditions with grit flying everywhere. I'd rather the filter take the abuse than the lense.
01-24-2009, 07:59 PM   #29
8540tomg's Avatar
I use SMC Pentax UV filters on my lenses when I use filters. I don't know if Pentax filters are any better than the other manufacturers but I always felt if there were any advantage to having SMC coatings on the lenses I might as well have it on the filters as well.
Tom G
01-24-2009, 09:23 PM   #30
heliphoto's Avatar
No kidding, you really don't mess around. I think you could still sell that one on ebay, "for parts - already disassembled". I hope the story (whether it's the truth or not) is suitably exciting?... do tell.
k-mount, pentax lens, slr lens
lens filter poogeek Troubleshooting and Beginner Help 14 05-01-2010 09:25 AM
Filter for macro lens bobmaxja Pentax Camera and Field Accessories 1 04-26-2010 08:04 PM
Filter saves lens Ash Pentax SLR Lens Discussion 5 04-19-2009 03:13 PM
Why lens filter do I need? momof4 Pentax SLR Lens Discussion 7 10-22-2007 06:15 AM
Filter for my new lens?? Buschmaster Pentax SLR Lens Discussion 9 10-12-2007 09:14 AM
All times are GMT -7. The time now is 02:13 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
