01-18-2009, 10:08 PM   #1
Douglas_of_Sweden's Avatar
DSLR wide angle in the ~13 to 16mm range, what are the choises for Pentax
I'm longing for a prime that for APS-C corresponds to something in the 20-24mm range on film SLRs, so 13-16mm, non fish-eye. Don't mind if it would happen to be full frame, but that is not the main purpose. What are the choises for a Pentaxian?
DA14/2.8? I've researched it on the forum and elsewhere, and it appears to me that it get very different verdicts, some people like it, others not. Why?
Comming DA15 limited? What speed will it have? Price?
Anything else? Third party?
Older lenses? The Tamron or Tokina 17mm are close in focal lenght, are they an alternative? Might be able to live with MF. Anything else legacy?
Hope someone have some advice. Example pictures very welcome!
01-18-2009, 10:14 PM   #2
Sigma 10-20mm EX DG (srry, don't know the aperture range) would be a good choice seems like.
01-18-2009, 10:31 PM   #3
rpriedhorsky's Avatar
It's digital, so you can remove lens distortion in PP, even fisheye, particularly if you have a fancy tool like PTLens. Worth considering since wide-angle lenses with low distortion can be expensive and heavy.
01-18-2009, 10:34 PM   #4
SpecialK's Avatar
OP does not want a zoom.
I suggest going to Adorama and search for lenses with Pentax mount.
01-18-2009, 11:03 PM   #5
Douglas the images of the DA15LTD show it having an f4 widest aperture.
01-18-2009, 11:07 PM   #6
The Pentax DA 12-24mm/4 is quite good. I know that Tamron has put out their 10-24mm for Canon, so Pentax might be out already or soon to follow.
01-18-2009, 11:25 PM   #7
troyz's Avatar
QuoteOriginally posted by Douglas_of_Sweden Quote
FWIW the manual focus Tokina RMC 17/3.5 needs to be stopped down to at least f/5.6 to get reasonable contrast.
(Tokina 17, f/8, ME Super, Kodak 400UC, Coolscan V, taken while standing on garbage can)
01-19-2009, 12:53 AM   #8
QuoteOriginally posted by troyz Quote
Thanks for the advice and the photo. You wouldn't have a shot with the lens further open to demonstrate how soft it goes? Does it have the A contacts?
Do you know if the Tamron 17mm is better? I've heard people claiming both. At least I already have two adaptall 2 KA mounts so I would have covered that part of the cost already, and I could use any of those two lenses on my film cameras as well.
01-19-2009, 12:54 AM   #9
Marc Sabatella's Avatar
KEH has both the "K" and "A" versions of the 15/3.5 right now, but they aren't cheap. There is also the Zenitar 16, ostensibly a fisheye but the effect is apparently not as severe on APS-C as on FF and in any event is very easily corrected - I know several folks use it as a general purpose super-wide, snce it is so cheap.
01-19-2009, 12:57 AM   #10
QuoteOriginally posted by tybeck Quote
QuoteOriginally posted by Dtkeith Quote
Sory, don't want a zoom. Planning to replace the DA18-55 with the DA16-50 and then the DA10-17+DA16-50+DA50-135 will be just as much zoom as I want.
What I'm looking for now is to maybe complement my primes with something in the 13-16mm range.
That is actually a valid question. Is the DA16-50/2.8 good enough at 16mm to replace a prime?
01-19-2009, 01:02 AM   #11
Thanks Marc, I will take a look. Do they ship to Europe?
I think this would have been a tempting option had I not had the DA10-17 fisheye, which I'm very hapy with. What I'd like to have is a prime with as little distortion as possible, and faster than the DA10-17 (I am looking for an older fisheye for my film cameras, for the right price, but that is a less prioritised project right now than a wide angle prima).
01-19-2009, 01:04 AM   #12
QuoteOriginally posted by Rico Quote
So it will be slower than the DA14/2.8, but probabl more compact. The DA14 is a bit bulky.
QuoteOriginally posted by rpriedhorsky Quote
I have played around a little with that on shots taken with the DA10-17 fisheye, but even when it works fine, it takes time.
01-19-2009, 01:05 AM   #13
raider's Avatar
I have the DA14 and I like it. In fact I used it more than other lenses during any field trips.
01-19-2009, 03:26 AM   #14
Lens choice is pretty subjective and each is looking for different things.
I think it is easy to order Zenitar 16mm from Russia in Sweden.
My widest lens was used to be FA28mm which is not very wide indeed
Zen has long list of ardent users
Zenitar 16 FE- presentation and samples: Pentax SLR Talk Forum: Digital Photography Review
Daniel
01-19-2009, 06:34 AM   #15
Wheatfield's Avatar
I quite like the 14/2.8, though mine does have issues with accurate AF. It is definitely a notch above the A15/3.5 on the digital. I have both, so I've been able to compare them side by side. The 14 is about the same size as the A15/3.5 but significantly lighter.
choises, k-mount, pentax lens, range, slr lens
Pentax 10-16 mm wide angle ? lesmore49 Pentax News and Rumors 35 04-10-2010 06:34 AM
Is it possible to have an electronic range finder feature in future Pentax DSLR? fearview Pentax News and Rumors 13 04-01-2009 05:15 AM
For Sale - Sold: Pentax DA 12-24 Wide Angle TakeshiKovacs Sold Items 2 02-03-2009 02:54 PM
Best pentax wide angle? simp Pentax SLR Lens Discussion 14 10-28-2007 10:37 PM
Does Pentax has old wide angle lenses? mulder Pentax SLR Lens Discussion 3 08-07-2007 04:03 AM
All times are GMT -7. The time now is 09:14 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
