01-19-2009, 08:42 AM   #1
Syb's Avatar
M42 lens on a DSLR: how to stop down?
This may have been discussed here a thousand times already, so if it was, please point me to the thread I couldn't find myself... I have a 16mm Zenitar fisheye on a M42 mount, that I would like to use on DSLR. That is: use the aperture ring to stop down.
I have a M42 to K mount adaptor, but that does not do the trick.
Makes me wonder: is what I want, impossible or is there a trick I do not know of? There is a pin on the mount side, that - if pressed - sets the aperture. But it looks as though the pin is not moved by the camera body. Is there a way to use the lens better than just wide open?
Thanks,
Syb
01-19-2009, 09:01 AM   #2
I'm new to this, like you. I found an explanation a few weeks back and I will try to find it for you. But as I recall, these are the steps:
1. Open the lens up wide (lowest f-stop) and focus your shot.
2. Select the f-stop you want to use.
3. With the lens aperture set, use your camera's metering to set shutter speed for proper exposure and shoot.
01-19-2009, 09:18 AM   #3
Syb
Syb's Avatar
Yeah, that is the way to proceed. But selecting the desired F-stop is something else. That action (turning the ring) should be followed by a response (smaller iris in the lens). Fact is that that doesn't happen.
I found that there are M42 lenses with an Auto/Manual lever, making it possible to work with or without the stopping down pin.
My Zenitar does not have that feature. Just a pin.
When the pin is pushed in manually (off the camera), the aperture does work properly. However there is nothing in the camera body that pushes the pin.
While trying and trying all of a sudden I pushed the pin in and it did not pop back out again.
Now what a pity that is....
... my problem is solved! Stopping down is by choosing the desired f-stop. Viewfinder gets darker then. But focus was done wide open already. Problem solved! Yay!
aperture, dslr, k-mount, lens, m42, m42 lens, mount, pentax lens, pin, slr lens, trick
f stop calculation with 67 lenses on dslr mtdevlin1954 Pentax SLR Lens Discussion 2 10-24-2009 08:59 PM
MF M42 on a DSLR Question.. arbib Pentax SLR Lens Discussion 3 10-05-2009 08:15 PM
How to stop down an M42 on a K-mount camera scimitar12 Troubleshooting and Beginner Help 6 04-19-2009 10:59 AM
How to use Fujica M42 lens on Pentax DSLR vanchaz2002 Pentax DSLR Discussion 16 06-02-2008 07:56 PM
Stop down method on K-Body (m42 and manual K) Duh_Vinci Pentax SLR Lens Discussion 4 12-23-2006 01:20 AM
All times are GMT -7. The time now is 07:29 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
