Just thought I'd share. This is on my evil Canon, but the same should work fine on any Pentax body (or any other body that lets you meter and shoot without it seeing a lens attached).
Did the following:
Dremeled out the center portion of a body cap.
Took a Cokin 49mm mount ring I had sitting around and superglued it (try to center it accurately) so that the thread pointed outwards. You could also use a filter with the glass knocked out.
Finally, screwed a Super Tak 50 to the ring (give it an hour or so so that there's no trace of superglue fumes, that stuff WILL mess things up!).
Unfortunately, weather was crap so had to try a couple of shots inside. I plan to use a pocket bouncer with the flash in forward facing position so it basically puts the reflector on top of the subject, but for this shot I used a 420ex on a cord.
100% crop from the above. The Super Tak does well even reversed.
