01-23-2009, 06:21 PM   #1
wilkin's Avatar
Takumar Bayonet 28mm f2.8 reverse mount
hey everyone, this is my first post other than the intro post :P
well I recently got a Takumar Bayonet 28mm f2.8 and a Vivitar MC Tele Converter 2x-22 and both are K mount for my ist DL
the question I have is how do I reverse mount the Takumar to the Tele Converter?
all the help is much appreciated!
01-23-2009, 10:02 PM   #2
Damn Brit
Guest
With a K mount reversing ring. One side has the K mount the other side should have the same filter diameter as the 28mm lens.
01-23-2009, 10:18 PM   #3
wilkin's Avatar
for that lens being 28mm does that mean the lens filter diameter would be 28mm?
01-24-2009, 07:21 AM   #4
I tried looking for information on this particular lens but I can't find the size of the filter. It doesn't look like it is available online, it usually is printed in the documentation or on the face of the lens. You could use calipers if you had them handy, or a metric ruler, be sure to carefully measure the Inside Diameter of the filter ring on the front of the lens.
HTH,
Southy
01-24-2009, 12:46 PM   #5
wilkin's Avatar
good idea, I have a caliper at work!
01-24-2009, 01:01 PM   #6
Takumar 28/2.8 Bayonet
Says the Takumar Bayonet 28/2.8 has a 49mm filter ring.
Glue one to a body cap or buy a 49mm-K reversing adapter: http://shop.ebay.com/?_from=R40&_trksid=m38.l1313&_nkw=reverse+adapter+penta...All-Categories
01-24-2009, 01:36 PM   #7
wilkin's Avatar
thanks for the great info!
appreciated as always
01-26-2009, 02:17 AM   #8
If you are planning to do some cheap macro, try the macro extension tube instead, it's much better than the reverse macro ring. Reverse ring only works with a fix diameter lens, but a extension tube can mount to any K lenses. and it has 3 different type of macro ratio.
28mm, bayonet, bayonet 28mm f2.8, converter, f2.8, k-mount, pentax lens, post, slr lens, takumar, takumar bayonet 28mm, tele
Faulty Pentax Takumar Bayonet 28mm f2.8? NiftyFifty Pentax SLR Lens Discussion 6 07-21-2010 08:26 PM
Differences- 28MM TAKUMAR-BAYONET +SMC M 28MM albrechtnamatdurer Pentax SLR Lens Discussion 12 11-20-2009 03:13 PM
Takumar 28mm F2.8 Bayonet furby Pentax SLR Lens Discussion 3 08-12-2009 05:12 AM
All times are GMT -7. The time now is 12:42 AM. | See also: NikonForums.com, part of our network of photo forums!
