03-22-2007, 11:21 AM   #1
button's Avatar
K mount lens to 645?
Is there a way to mount K mount lenses (ex. FA 50mm 1.4) to the 645? What an incentive to buy the new 645D if you already have a bunch of SLR lenses, no? Imagine a 31mm ltd on this camera.... WOW!
03-22-2007, 04:17 PM   #2
Image circle is way too small. Mounting 35mm FA lenses on a 645 would be similar to mounting the DA14 on a 35mm Film camera - you'd get a nice circular image
03-22-2007, 04:53 PM   #3
Ole
Ole's Avatar
Adding to the privious post: You will not be able to focus to infinity, not even close. The lens would be mounted to far from the sensor. The 645 body is much deeper than a 35mm SLR due th the space required for the bigger mirror.
03-22-2007, 07:11 PM   #4
button's Avatar
I knew it was too good to be true. Thanks for the explanations.
k-mount, lenses, pentax lens, slr lens
645 lens to k mount questions blackcloudbrew Pentax SLR Lens Discussion 4 10-25-2010 12:26 PM
Hartblei T/S on a 67? 645 mount? markolw Pentax Medium Format 6 11-13-2009 07:54 PM
All times are GMT -7. The time now is 06:34 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
