Originally posted by Lowell Goudge
one thing I noticed is that the tap on the wall is not at the center of the frame, where focus sensor would be expected to pick up focus confrimation with an AF sensor.
what did you focus on, and how did you focus because your assessment may be more related to focus error (by the operaotr) than the lens sharpness improving.
I do agree however withthe assessment of CA and this does improve as you stop down.
just as an aside, the K300 F4 has slightly shorter focusing (down to about 11 feet) and 270 degrees of focus collar rotation.
Additionally (just to keep peter Zack and others from pointing this out) You should put the technical aspects of your review in the database
Thanks Lowell for the feedback. I
believe I focused on the tap, though as you say, If my focus is off a bit, it would show the sharpening from the increased DOF... I tend to just look for sharpest focus in the viewfinder, and not to use the focus confirmation when manually focusing, because I never got good results on my K200D that way, so I got out of the habit (never got into the habit). Now on my K20D, I notice that I get the green hexagon when I think I've nailed the focus, so it does work as confirmation, but I don't think I rely on it yet... If you're interested in pixel-peeping (the ivy shot for instance), the full sized images are available (link is in the blog post). I don't have a Katz-eye or similar split image screen, so it's possible I was a bit off on focus - I dunno. Based on the this DOF calculator, it looks like the DOF with this setup (estimating 30' to the tap) would be ± 6 in. so I was clearly
trying to focus on the tap, whether I succeeded or not
I do intend to put writeups in the database, after I've had these lenses a while longer in order to form opinions on 'em.
