04-14-2009, 05:01 PM   #16
-=JoN=-'s Avatar
i had something similar happen.
my zoom would get stuck at 19mm and not all the way to 16.
and if you shook the lens, something was loose. this happened, 7 months after purchase, i went back to Calumet, and told them, the took care of it for me..(sending it out pentax, and dealing w/ it...) i got it back, about a month later....works fine now..
04-14-2009, 05:35 PM   #17
maxwell1295's Avatar
I'm in the market for the 16-50, but these failing SDM threads (and there are quite a few of them) are starting to scare me. It seems to happen more often with the 50-135. I don't know if it was from the early production runs and was fixed in subsequent runs or if there is a real problem with Pentax SDM.
04-14-2009, 09:15 PM   #18
-=JoN=-'s Avatar
QuoteOriginally posted by maxwell1295 Quote
my 50-135 has been perfect since day 1. got it a month or 2 after release...the 16-50 is a workhorse, so it's been used more than the 50-135...but aside from that one issue, and it was still under warranty, it has been good...
04-15-2009, 12:25 AM   #19
247nino's Avatar
I have never had problems with my 50-135 and i've had it longer than the 16-50, its also been in the rain just as much.
04-15-2009, 09:15 AM   #20
My 50-135 has also been perfect from Day 1. I expect the 16-50 to get a lot of use (mostly for events) so I'm a little leery because of the SDM issues I've been seeing lately. Hopefully, Pentax found a remedy and it's not the newer SDM models that are having these problems.
04-27-2009, 08:44 PM   #21
247nino's Avatar
Got it back today so it was gone about 13-14 days,
Replaced zoom barrel, rollers and guides, one year warranty renewed.
the zoom ring is a little tighter now, but thats good, better than loose... so now only time will tell if it will lock up on me again. Pentax's turnaround time was pretty good.
03-25-2010, 07:30 PM   #22
QuoteOriginally posted by 247nino Quote
How much was the cost on that? Just wondering, looks like my SDM died last night, and I don't have a non-SDM body to try out screw drive focusing on.
03-26-2010, 04:59 AM   #23
Ben_Edict's Avatar
QuoteOriginally posted by amoringello Quote
Twice in the past three weeks, my DA* 16-50 would not zoom. I tried to turn the barrel but it is jammed. I removed the lens tapped it on its end lightly and then it worked just fine.
A few days ago it refused to auto focus. After some use it freed up and works again.
Obviously I need to send for repair, but has anyone else had these sorts of issues?
Rather depressing, dunno whether I should just buy new, or wait eight weeks for repair. (May cost as much anyway... ergh!)
That happened to my own DA 16-50 within three months after buying. It was blocked completely and also gave up on AF. I got it repaired under warranty, but saw the estimate: 260 Euros - if I'ld payed for myself. Not a cheap repair, but definietely cheaper, than any new lens.
Ben
12-13-2016, 11:05 AM   #24
Michi Joel's Avatar
QuoteOriginally posted by -=JoN=- Quote
+1 today begins to fail, same problem. I'm tavelling in Iceland, i don't know if the cold is the problem...
da*, focus, k-mount, pentax lens, repair, slr lens, weeks
AF-540FGZ zoom stuck at 16mm?? joeyc Pentax Camera and Field Accessories 9 04-03-2012 05:08 PM
16-45mm zoom AND focus ring stuck! mab18 Pentax SLR Lens Discussion 0 03-11-2010 08:21 PM
Zoom stuck Adaptall 60-300mm Hiroshi Pentax SLR Lens Discussion 2 11-29-2009 12:57 PM
Stuck zoom ring photogwannabe Pentax SLR Lens Discussion 5 06-08-2009 03:31 PM
af540fgz stuck in manula zoom rjdesq Flashes, Lighting, and Studio 4 06-29-2008 06:47 PM
All times are GMT -7. The time now is 06:27 PM. | See also: NikonForums.com, part of our network of photo forums!
