01-28-2009, 02:52 PM   #1
Question about Pentax DA 40mm 2.8 and filters
Just ordered this lens online, i know it has screw mount lens cap- Does it take a regular fitting 49mm filter? if so , will the hood attach to it?
Thanks
01-28-2009, 03:14 PM   #2
GSk
I think the answer to your question is yes.
I keep the lens hood on this one all the time, it is so small that it doesn't matter. With the lens hood on, the front element is very well protected. In fact this one and the 70mm Ltd are the two lenses that I do not use a filter for protection og the front element.
01-28-2009, 03:16 PM   #3
axl
If by regular fitting you mean 49mm screw in filter, than answer is YES, to both. 49 mm filters will easily screw into the filerthread and the lens hood will screw nicely onto it...
...but be careful how thick filter you will put between the hood and the lens! If it's going to be too thick it may cause some vignetting (I can't confirm this since I never use original hood with filters)
BR
Peter
01-28-2009, 03:16 PM   #4
farfisa's Avatar
Yep, that's how it works.
The screw in hood will provide a lot of protection too if that's what you're thinking about.
01-28-2009, 04:22 PM   #5
Sailor's Avatar
QuoteOriginally posted by kevinfox203 Quote
Thanks
It does take a 49 mm filter, but - if you're thinking of a more-or-less permanent UV filter, there is an alternative: you can screw a 30.5 mm filter into the hood of the lens, which then attaches normally - thus you avoid the extension caused by a conventional 49.
Jer
01-28-2009, 06:02 PM   #6
thanks for the replies. Now I can order filter. BTW good prices at hvStar.com >>>Photo, Digital, Video Game ON SALE (MaxSaver; BestEastern; hkDirect; hvPhoto) Select B&W filters have free shipping until Jan 31st
k-mount, lens, pentax da 40mm, pentax lens, question about pentax, slr lens
filters or caps for the DA 40mm Ltd braver Pentax SLR Lens Discussion 16 10-06-2015 11:02 PM
Pentax DA 40mm Limited focus question daveboettger Pentax SLR Lens Discussion 8 01-19-2010 01:15 PM
which 40mm? pentax da 40 or Voigtlander Ultron 40mm f/2.0 SL-II dexmus Pentax SLR Lens Discussion 12 10-30-2009 07:26 PM
Question about filters? djayvo Pentax SLR Lens Discussion 3 12-08-2008 09:51 PM
For Sale - Sold: FS: DA 40mm f/2.8 Limited; Hoya, Tiffen filters zaurus Sold Items 4 04-15-2008 03:24 PM
All times are GMT -7. The time now is 10:37 AM. | See also: NikonForums.com, part of our network of photo forums!
