Originally posted by legolas Thank you for reply.
Can you please tell me that 50-200 is a complementary lens for 18-55 or we can replace 18-55 with a 50-200?
Do you know what the numbers mean? 18-55mm refers to the range of focal lengths of the lens (as does 50-200mm for the other lens). As to whether or not you can replace the 18-55 with the 50-200, that depends on whether or not you NEED the 18-55mm range. Play with your 18-55 lens for awhile. Do you wish to get closer to your subjects? Then you need a LONGER (ie a number bigger than 55mm) lens. 18mm not wide enough? Then you need a focal length shorter than 18mm (The Sigma 10-20mm, Pentax 12-24mm, or Pentax 10-17mm).
Learn what the specs (ie 'numbers') of the lenses mean, spend some time with your 18-55mm, then you will know what you need (or don't need).
Good luck!
