02-02-2009, 07:19 AM   #1
DA 21mm + UV filter + lens hood -- help me?
i'm finding an info about DA 21mm.
i know: it is possible to put a UV filter 49mm, but then it is not possibile to put the original (and little) lens hood (=>vignetting).
it is right?
so i ask you: can you tell me info about a "not original pentax lens hood" good for DA21mm + UV filter 49mm?
("not original pentax lens hood" good = no vignetting and no too big)
idea?
02-02-2009, 07:23 AM   #2
here:
DA 21mm
DA 21mm + original (and little) lens hood
02-02-2009, 08:15 AM   #3
heatherslightbox's Avatar
Your best bet would be to get a 43mm UV filter, which will screw onto the backside of the little lens hood, which will attach to the lens itself. 43mm UV filters aren't that hard to find; you can get them at places like Adorama, B&H, and Fleabay.
HTH,
Heather
02-02-2009, 08:15 AM   #4
I'm looking at a DA21 right now. You're right, a 49mm filter on the lens would block the included hood.
But, I see filter threads on the inside of the hood! Markings on the hood say 43mm, so that might be the thread size. You should be able to screw a filter onto the inside of that hood.
Yup, just confirmed it with the online manual. 43mm filters, attaching to the inside of the hood.
EDIT: Ooops too slow!
02-02-2009, 08:28 AM   #5
QuoteOriginally posted by hwblanks Quote
HTH,
Heather
QuoteOriginally posted by deuces Quote
thanks for info.
i thought about a 43mm filter, but i think to use a 49mm UV filter Hoya S-hmc because it is a good uv filter.
and it is not avaible a good 43mm uv filter: Hoya S-hmc is avaible only from 49mm.
i want to put a good filter.
so where i can find a good 43mm filter?
or maybe i prefer to find a lens hood for 49mm uv filter...!
02-02-2009, 08:39 AM   #6
QuoteOriginally posted by gemini Quote
thanks for info.
Here you go. But whoa! I didn't think a 43mm would be so expensive. I believe the B+W multicoated UV are considered at the top of the heap.
66023185 B + W 43mm UV (Ultra Violet) Haze Multi Coated Glass Filter, (2C) #010
66042012 B + W 43mm Digital Pro UV (Ultra Violet) Haze Multi Coated (2C) Glass Filter #010
02-02-2009, 08:43 AM   #7
but about you, there is not a good solution for 49mm uv filter?
for example:
DA 21mm + UV filter + empty 49mm filter (for lens hood)
02-02-2009, 09:32 AM   #8
StevenVH's Avatar
While considering this lens for my next LBA episode I realized the hood/filter issue. My conclusion was to use a 49mm filter and try different folding rubber hoods (cheap!).
hth
02-02-2009, 10:39 AM   #9
I got my 43mm Hoya multicoated filter from Adorama:
AD43UVGB Hoya 43mm UV (Ultra Violet) Multi Coated Glass Filter - Silver Mount
Sure, it's silver, but since it's mounted on the inside of the filter, it's not noticeable.
HTH,
Heather
02-02-2009, 11:27 AM   #10
HTH,
Heather
it is very strange because in Hoya website
HOYA FILTERS - The Difference is Clear
43mm UV filter there is not!
do you remember the color label of the box?
green? black?
02-02-2009, 12:33 PM   #11
troyz's Avatar
green? black?
I have it (43mm, silver rim, HMC), and I never use it. PM me if you want to buy it.
02-02-2009, 05:20 PM   #12
green? black?
I have the box right in front of me and it's silver.
Heather
02-02-2009, 07:33 PM   #13
....so i ask you: can you tell me info about a "not original pentax lens hood" good for DA21mm + UV filter 49mm?....
I use a B+W 49mm metal screw-in hood with my 21mm. Works fine with any filter, including polarizers.
Richard
02-02-2009, 10:22 PM   #14
QuoteOriginally posted by StevenVH Quote
hth
This is slightly on-topic: I have two 49mm metal hoods, purchased on ebay. They're cheap, but they don't look cheap and I'm slightly superficial. Rubber hoods look silly.
As for "B+W" lens hoods...that's just profane. My lens hoods are made by the renowned "Asian" company. All I can say is that, with some effort, I can put them on my lens.
EDIT: Gemini, don't buy a UV filter. They're probably a waste of money, if you're not shooting on film.
02-03-2009, 02:02 AM   #15
Heather
very thanks
21mm, filter, info, k-mount, lens, pentax, pentax lens, slr lens, uv
Lens hood with filter window AndyB Pentax Camera and Field Accessories 10 04-11-2010 02:58 AM
Do I need a lens hood and a filter for K2000 Agesconde Troubleshooting and Beginner Help 25 06-07-2009 10:27 PM
Filter on hood or lens? user440 Pentax Camera and Field Accessories 5 05-30-2008 09:12 PM
All times are GMT -7. The time now is 08:09 PM. | See also: NikonForums.com, part of our network of photo forums!
