Originally posted by Wheatfield The A lens doesn't have a chip, so the camera has nothing to recognize. Input focal length manually when the camera asks for it on startup. You will not have FL available in EXIF though. (Atleast not that I've been able to make happen).
Lightroom seems to recognize the focal length when I use my 400. I have focal lengths in the EXIF showing 400 and 550 (the closest I can get to 560 = 400 x 1.4) with the convertor. K10D and output is PEF. I have not checked to see if DNG drops some EXIF data.
[EDIT] Here's the EXIF data from the first image in my Flcikr stream with the 400/5.6 M lens. I entered 400mm as the focal length for the shake reduction on startup. This is not in the manufacturer's segment, but the lower segment with the exposure data. I have highlighted the appropriate line. The image was taken in RAW/PEF on the k10d during some testing on the exposure variations with the meter in the newer digital cameras.
* Exposure Time (1 / Shutter Speed) = 1/180 second = 0.00556 second
* Exposure Program = manual control (1)
* ISO Speed Ratings = 400
* Exif Version = 0221
* Original Date/Time = 2008:03:06 15:55:47
* Digitization Date/Time = 2008:03:06 15:55:47
* Shutter Speed Value (APEX) = 7491853/1000000
Shutter Speed (Exposure Time) = 1/180 second
* Exposure Bias (EV) = 0/10 = 0
* Metering Mode = center weighted average (2)
* Flash = Flash did not fire, compulsory flash mode
Focal Length = 40000/100 mm = 400 mm
* Image Sensing Method = one-chip color area sensor (2)
* Colour Filter Array (CFA) Geometric Pattern = 0x02,0x00,0x02,0x00,0x00,0x01,0x01,0x02
* Custom Rendered = normal process (0)
* Exposure Mode = manual exposure (1)
* White Balance = auto (0)
* Focal Length in 35mm Film = 600
* Scene Capture Type = standard (0)
* Contrast = hard (2)
* Saturation = normal (0)
* Sharpness = hard (2)
* Subject Distance Range = distant view (3)
