Wow, lots of confusion here. here are some of my observations:
"- One of the basic questions has to do with focus adjustments. Those affect AF only. This is an MF lens. So no, the focus adjustment won't change a thing. It's ossible the focu screen is misalgined, or it's ossible you are being fooled by the fact that the focus screen shows a slightly deeper DOF than the lens actually produces at f/2.8, it's possible that the lens will not focus to infinifty any more, and it's possible that you simply need practice focusing manually on this camera. Seem to recall you come from a film background; you may be accustomed to larger viewfinders with split focus screens."
--Accustomed to larger finders, yes. Also, yes, faster lenses with generally narrower FOV's. The reason I broke down and got this 28 is in fact, cause apparently the focusing screen can't tell the difference, anyway, cause it's brightened for slower lenses, and disregards anything from wider than about 3.5 anyway.
Still, I'd expect to be finding *something* sharp in the field.
Don't care much for split screens and never did, though I wish the green hexagon were less vague, for when I *would* like a little help. If I had Pentax's ear, I'd have them make what I jokingly called my 'Ratzeye' screen, with a microprism for fast lenses for quick MF, around a matte circle which would allow critical focus and keeping an eye on the AF.
- Regarding transmission of lens info: it seems to me PhotoME is simply *guessing* based on the SR focal length entered and the minimum and maximum aperture reported by the lens (all of which *is* recorded in the EXIF). My A50/1.7 is reported correctly when I enter 50mm as the focal length in the SR menu, but if I lie and enter something else, PhotoME gets confused and makes other guesses (including 135/1.8 if I enter 28mm as the focal length). It may be a pretty clever a lot of the time, but it's capable of some gaffes as well.
Ah. OK. That was actually a theory I had voiced earlier, to try and reconcile all reports, but no one seemed to think much of it.
Apparently at least the SR part of the programming can't make this leap, so who cares, except posterity.
[ edited ]
"- Not sure what is going on with exposure. If I understand correctly, you are saying you hit the Info button while in Av or P mode and th displayed shutter speed is long."
When I make an exposure in seemingly anything but M or Tv (on the dial, not necessarily via hyperprogrammey things) ...it seems, by sound and results, the proper exposure happens. Say it's... 1/90 sec at 4.5. Exposure happens properly. Then, the chimping image comes up on screen. You hit 'INFO.' This information says maybe 6s 4.5. This report usually says it's in whole seconds. Unless I deploy the flash, then it reads 1/180 there.
OK. That's not right. RML makes annoyed sounds. Out of chimping mode. Hit the playback mode button. Voila. Exposure info says something at least like what actually happened. Probably this is the EXIF.
Still not sure if the initial problem means something is broken.
" Well, you are pointing at something dark while doing so? It's going to display the shutter it thinks will be necessary at that moment. When I chimp the lCD, my natural tendency is to point the camera down at my feet. So of course I get a slow exposure..."
This is the info about the exposure being reviewed.
"- I'm also not sure what you mean about the focal length not being reported in the camera. If you've set in in the SR menu, and have SR turned on, then the rear LCD should display the focal length you entered. It does not display focal length when SR is not turned on.
