02-08-2009, 10:50 AM   #16
audiobomber's Avatar
QuoteOriginally posted by kristoffon Quote
I got some pretty good results with a reversed 50mm on top of the 18-250mm
Bee Shot II is exceptional. It looks like you had the 18-250 zoomed to around 24mm (1:2 macro)?
Would you mind telling me how you set the apertures?
02-08-2009, 11:07 AM   #17
QuoteOriginally posted by pentagor Quote
This is possible only if the extension tubes have the aperture lever. Most cheap Chinese ones doesn't.
But using the green button isn't exactly the auto exposure metering. Auto exposure is IMO only possible with PKA mount lenses (and newer of course).
If you mean the camera causes the lens to stop down at exposure time you are correct. I meant metering after manually stopping down. My bad.
Dave
02-08-2009, 11:48 AM   #18
pentagor's Avatar
QuoteOriginally posted by newarts Quote
Dave
Oh, yes of course. I didn't understand you, because when I manually stop down the lens, I never use a green button. I just manually set the speed and then look at the exposure...
We did understand each other now...
02-08-2009, 01:37 PM   #19
kristoffon's Avatar
QuoteOriginally posted by audiobomber Quote
Thanks for the compliment.
The prime is left wide open all the time, the base lens controls the aperture (and DOF). Closing the prime's aperture has no effect on DOF, it just decreases the size of image the base lens can "see". 24mm already had black corners, so cropping was needed.
angle, extension, f8, k-mount, kiron, kit, lens, m50/1.7, macro, magnification, method, pentax lens, slr lens
300mm lens test, 5 cheap options Just1MoreDave Pentax SLR Lens Discussion 21 12-13-2010 04:20 PM
Any cheap options for a lens wider that 18mm? kevinschoenmakers Pentax SLR Lens Discussion 16 04-04-2009 05:26 AM
real world long lens options compared Lowell Goudge Pentax SLR Lens Discussion 22 07-06-2008 12:47 PM
Macro options.. hrishi Pentax SLR Lens Discussion 12 06-14-2008 07:04 PM
Cheap macro options? heatherslightbox Pentax SLR Lens Discussion 18 01-17-2008 09:54 PM
All times are GMT -7. The time now is 08:19 PM. | See also: NikonForums.com, part of our network of photo forums!
