02-09-2009, 10:15 AM   #1
How much focus would I loose mounting a m39 on my pentax?
Would it be useless to anything other than portraits / Macro / interior photography?
Thinking about the helios-40, cant find a m42 version out there.
02-09-2009, 11:54 AM   #2
Steinback's Avatar
Depends on what adaptor(s) you use. My m39 to m42 adaptor has a flange (it sticks out from an m42 body) but I use it on a bellows lens so it doesn't really matter. I've read about m39 adaptors that will mount flush inside one of the genuine Pentax m42 adaptors but I don't know where you might be able to get one.
02-09-2009, 12:52 PM   #3
troyz's Avatar
QuoteOriginally posted by melander Quote
EDIT: discussion below is for m39/Leica rangefinder screw mount -- as Quicksand notes below, not applicable to Zenit SLR m39 screw mount.
I've never tried it, but i'd expect it to be useless for anything but macro/close focus. The flange focal distance for m39 (Leica Screw Mount) is 28.8mm, for m42 is 45.5mm, so putting a m39 lens on an m42 body is like using a 16.7mm extension tube.
Thin lens forumula says
1/object distance + 1/focal distance = 1/focal length
Suppose you mount a 50mm m39 lens focused at infinity. You've increased the focal distance from 50mm to 66.7mm; so you get
1/max object distance = 1/focal length - 1/focal distance
= 1/50-1/66.7
which works out to
max object distance = 200mm (somebody please check my math).
With wider lenses you're even more hosed.
02-09-2009, 12:56 PM   #4
pentagor's Avatar
troyz, you're right. I tested my M39 50mm lens from Zorky rangefinder on my K100D and it is useless.
02-09-2009, 05:30 PM   #5
But there is the Zenit version of M39 (for SLRs, not rangefinders) which has a register distance comparable to (if not exactly equal to) Pentax.
It's confusing, and there's a lot of contradictory information out there.
Take a peek at this thread:
Manual Focus Lenses :: View topic - Camera mounts and register distance
02-09-2009, 05:57 PM   #6
troyz's Avatar
QuoteOriginally posted by Quicksand Quote
Thank you for pointing this out. I've edited my previous post.
focus, k-mount, m39, pentax lens, slr lens
FA 31mm limited focus ring is loose? kuau Pentax SLR Lens Discussion 16 06-28-2011 05:45 PM
DA L 18-55mm manual focus ring too loose jamesv93 Pentax SLR Lens Discussion 2 11-28-2009 12:03 AM
Possible to use M39 on Pentax winglik Pentax SLR Lens Discussion 3 05-06-2009 10:29 AM
Mounting a Topcon RE lenses on Pentax K chse Pentax SLR Lens Discussion 7 04-10-2008 06:51 AM
All times are GMT -7. The time now is 03:53 PM. | See also: NikonForums.com, part of our network of photo forums!
