02-10-2009, 01:40 AM   #1
zmohie's Avatar
new pentaxian need help
Hi all
this is the first time to post nwe thread in pentax forum
in fact i bought k200 since a month ,price was the main reson to buy it,ididnt think in colors,versatility,lens,only the price.so after shoting with DFA 100 MACRO,THE RESULTS WAS REALY AFFORDABLE AND I decieded to be pentaxian from now.
I INTEND TO BUY ONE LENS FOR BIRDS AND LONG SHOTS,AND ANOTHER ONE FOR GENRAL USE.
THANKS
02-10-2009, 03:21 AM   #2
Class A's Avatar
QuoteOriginally posted by zmohie Quote
You should probably indicate your budget, whether you prefer primes over zooms, how fast you want your lenses to be, whether you want AF and other automation features, etc.
The longest modern lens, I can think of, of the top of my head would be the BIGMA (Sigma 50-500mm). Would that one be too heavy and expensive?
Do you have the kit lens (18-55)? If so, do you not like it for general use and why not?
Answers to the above questions would help to assist you with your search.
02-10-2009, 04:28 AM   #3
axl
regardless budget:
Sigma 50-500 has quite a strong following, but have a look at DA*200 or 300 with 1.4 or 1.5 TC. They a regarded as very good lenses.
For general use, kit is not bad, if you want to upgrade it, Tamron 28-75 has quite a reputation, but could be better built, there is new DA17-70, or Sigmas 24-70, 24-60.
BR
02-10-2009, 11:31 AM   #4
zmohie's Avatar
QuoteOriginally posted by axl Quote
regardless budget:
BR
thanks axl
may be iwill buy da*300 with tc 5ر1
and da 17-70
02-10-2009, 11:34 AM   #5
zmohie's Avatar
thanks
BIGMA MAY BE HEAVY MORE THAN I WISH
THE KIT LENS IS GOOD BUT I NEED ANOTHER ZOOM LIKE DA 55-300
THANKS AGAIN
02-10-2009, 11:50 AM   #6
PentaxPoke's Avatar
Welcome to the family! My recommendation is the Pentax or Tamron 18-250. It is a very versatile lens, and will work well for your application. As you learn more, you might like to get a longer (but more expensive) "birding" lens. I think the 18-250 is a good start.
02-10-2009, 12:10 PM   #7
Lowell Goudge's Avatar
Hi all
good for you, and welcome to the forum
this is a tricky subject, and we can all give advise on how to spend well in excess of $6000 US or as little as $500 US. but as a good reference, I would suggest you look into a 70-200 F2.8 and a couple of high quiality Tele Converters, since this will be the most useable overall, or to go for one of the sigma zooms that reaches out to between 400 and 500 mm, but you will give up F2.8 for the 70-200 range
THANKS
there are more general use lenses than you can count, but look at anything that gives F2.8 across the focal length range you want. Sigma tameron and pentax all make fine lenses in teh range of 16-28 mm at the wide end to 50-80mm at the long end.
it is all as simple as going out and spending money.
02-10-2009, 12:51 PM   #8
zmohie's Avatar
[QUOTE=Lowell Goudge; but look at anything that gives F2.8 across the focal length range you want. Sigma tameron and pentax all make fine lenses in teh range of 16-28 mm at the wide end to 50-80mm at the long end.
.[/QUOTE]
f2.8 in a zoom lens is more expensive than I WISH but iam thinkig about DA55-300,regrdes for abird lens i intend to buy DA*300
THANKS FOR ADVICE.
02-10-2009, 01:24 PM   #9
Ben_Edict's Avatar
THANKS FOR ADVICE.
If you are seriously intending to photograph birds, 300mm will be very short to do so. You need a good tele converter to get a focal length more useful, like a 1.4x tc, which brings you up to 420mm , though you also end up at a maximum aperture of f/5.6, instead of the lens' f/4. I would therefor considering a good long tele zoom, which gives you more reach and more versatility, though even the Bigma is still half an f-stop slower at the long end. What you should also take into account (literally) is a good tripod, as these focal lengthes really afford a stable platform.
Ben
02-10-2009, 01:36 PM   #10
Class A's Avatar
If you are after a budget solution, I would recommend the 55-300. Seems to be a fine lens for the money.
Regarding the Tamron/Pentax 18-250, I own it and like it a lot, but I wouldn't recommend it for birding. It is rather slow at 250 (f/6.3) and you want to stop it down to ~f/8 for better IQ. The 55-300 will give you more reach, more than the nominal +50mm because the 18-250 only approaches true 250 when focused to infinity.
Regarding teleconverters, I suggest to not exceed x 1.7. The IQ of many 2x converters suggests that you may be better off with just cropping the image. Make sure you get a converter which supports the automation you are after. Not every converter supports the electrical contacts for A lenses, for example.
02-10-2009, 01:47 PM   #11
as I said in the intiial response, we can suggest anyting from 500 to 8000 for birding
So, just how serious a birding lens do you want.
For me, and I have been at this a while, I have never intentionally gone birding with a lens smaller than 77mm front element.
That is F2.8 at 200mm, F4 at 300mm and F5.6 at 400mm, and is why I suggested a 70-200 F2.8 zoom as the base lens. That lens and a couple of good TCs will be much more useable than either the BIGMA or any other of sigmas long tele's.
While some people, including myself have posted excellent shots with lesser lenses, including some bird shots at about 17mm, these are the exception.
A 50-300 F5.6 zoom, might leave you disappointed,
Maybe some of the existing owners can speak up and tell what they think of a lens like that, in moderate lighting conditions,
You might also want to consider the used market, as there are some bargins out there,
02-11-2009, 05:43 AM   #12
zmohie's Avatar
Ben,class,lowell
thanks for rich information,value conversation,
well after your answers i orderd da55-300 for normal use with the kit 18-55
and da*300 with 1,5 tc and i now have dfa 100 macro ,so i may be now become a real pentaxian in your community.
Thanks again to all pentaxian
02-11-2009, 10:47 AM   #13
Ben_Edict's Avatar
Ben,class,lowell
That was a big investment you have made and your choices look pretty good to me. Enjoy your new equipment and go out chasing birds!
Ben
k-mount, pentax lens, pentaxian, slr lens
a new pentaxian.. ezechiel Welcomes and Introductions 9 09-11-2009 01:02 AM
Another new Pentaxian. Peter Zack General Talk 24 08-20-2009 09:15 AM
Help for a pentaxian in need TheTenaciousOne General Talk 11 08-05-2009 01:38 PM
Another new Pentaxian WheresWaldo Welcomes and Introductions 1 07-25-2009 04:15 AM
New Pentaxian quenched Pentax SLR Lens Discussion 6 01-08-2009 03:43 AM
All times are GMT -7. The time now is 06:12 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
