02-12-2009, 08:56 AM   #1
How small are the DA limiteds?
I've seen pictures for comparison, but to you DA Limited owners, just how small are they? The smallest lens I've owned is the FA 50 (now belongs to someone else), and I currently own the 77. Though quite compact, I wouldn't put the 77 in the pocket of my jeans. I can tell the 40 is super super compact.
Anyways, just HOW SMALL are those DA Limiteds? And if you have a more than one and use them exclusively, how do you carry them around? The small size of these lenses becomes more and more appealing every day!
02-12-2009, 09:03 AM   #2
I own the DA40/2.8 and it's really small. As if it wasn't there.
02-12-2009, 09:27 AM   #3
I own the DA 40 as well. If you took the hood off it would probably be a little thicker than two UV filters when attached to your camera. It's pretty neat, but the lens is somewhat of a disapointment IMO.
02-12-2009, 09:42 AM   #4
How about the 21mm?
02-12-2009, 09:45 AM   #5
check the dimensions on the pentax site. the da21mm isn't so tiny that it's difficult to hold. for pics of the limited on a camera, check the photozone reviews
more pix of the 40mm
PentaxForums.com Lens Fact Sheet: SMC Pentax-DA 40mm
02-12-2009, 09:48 AM   #6
Nesster's Avatar
I found a photo or two making just the size comparisons you look for:
Pentax DA 21 40 70 en 77 on Flickr - Photo Sharing!
Pentax FA lenses - a set on Flickr
02-12-2009, 10:24 AM   #7
Sweet. Too bad that guy doesn't have the 31mm in there too!
Nice to know that the 21 isn't so flat that you can't hold it.
02-12-2009, 10:26 AM   #8
Gooshin's Avatar
too small
10char
02-12-2009, 10:37 AM   #9
farfisa's Avatar
The 70 usually looks big because it has that screw in hood, but it's very small too, and almost imperceptibly heavier than the 40.
Shocking, really.
02-13-2009, 04:20 AM   #10
axl
31 vs 40
here is direct comparison of 31ltd with 40ltd icluding hoods and caps:
02-13-2009, 04:42 AM   #11
Just right...
The DA 35 Limited w/hood in is about the same size and weight as the DA 70 Limited w/hood out. Goldilocks said it: "Not too big... not too small..." for the ones I know about.
Cheers...
02-13-2009, 06:40 AM   #12
farfisa's Avatar
QuoteOriginally posted by Michaelina2 Quote
Cheers...
The DA 35 is actually 5g shy of the weight of the 70 and the 40 combined. It's the only one you can actually feel the weight of.
02-13-2009, 06:55 AM   #13
fearview's Avatar
i always lose my da 40
for toooo smaill
02-13-2009, 12:17 PM   #14
PentaxPoke's Avatar
Here is my new 70 on my k20d. It is small and light, that's for sure!
02-13-2009, 12:34 PM   #15
AndrewG NY's Avatar
The 43, the 70, and the 21 are all comparable in size but the hoods on the 43 and 70 make them bigger than the 21 with hoods attached; both are screw-on and caps fit over the hoods so most likely you'll be leaving them on. I imagine with hoods they are probably longer than a hoodless FA50.
@JHfwp: disappointed by the DA40? I have FA43 but the DA40's supposed to be pretty good too, no? What don't you like about it?
da, k-mount, pentax lens, slr lens
Tenba Black Label Small Satchel - great small bag! andi Pentax Camera and Field Accessories 2 10-13-2009 07:44 PM
Small things amuse small minds artobest Pentax Film SLR Discussion 17 03-06-2009 01:38 AM
DA or FA limiteds? coloseu Pentax SLR Lens Discussion 14 02-24-2009 10:18 AM
FA* or FA limiteds Harmonica Pentax SLR Lens Discussion 12 10-09-2008 09:53 PM
Limiteds: 35/2.8 vs 43/1.9 paolojackson Pentax SLR Lens Discussion 4 09-30-2008 08:46 PM
All times are GMT -7. The time now is 01:03 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
