08-24-2010, 03:45 PM   #196
georgweb's Avatar
... I haven't decided if I want to spend $42 on the special m42 adapter for it.
I assume with such adapter you would lose infinity ?
M42 Mamiya Sekor SX 2.8/135 on K100D
08-25-2010, 02:03 PM   #197
AlexanderMayorov's Avatar
K-7 + J9
08-25-2010, 07:57 PM   #198
Blue's Avatar
QuoteOriginally posted by georgweb Quote
It shouldn't because the part that presses the pin is to the inside of the adapter. I have one for the Mamiya CS mount that is specifically made for the SX series lenses and it retains infinity.
The K-mount is from these people. The one with the "shoulder" is special order and 38 pounds. The price has gone up since I booked marked it.
M42 lenses on Pentax K
Edit: I need to take a pic of my Mamiya adapter. I think Yashica made one as well for their mount.
08-26-2010, 12:29 PM   #199
Spongefingers's Avatar
A Slippery Lot
K10D + Cosinon 50mm f/1.8, M42 extension tubes.
I use M42 lenses all the time - they've provided me with many of my favourite photos this year.
QuoteOriginally posted by Nesster Quote
Pentax is unique among the remaining camera manufacturers to maintain such a level of backward compatibility to the Golden Age of open source lens mounts. So let's mount them M42's and show off the results!
The M42 Crew.
This isn't really true. I consider the Canon EF mount much better suited (mechanically) for M42 lenses, simply because infinity focus can be achieved while using a sensible (flanged) adaptor; unlike Pentax which requires the inconvenient and fiddly in-mount type. I have one, but I don't like having to use it.
But this isn't usually a problem for me, as most of my M42 shots use extension tubes, so the extra 1mm doesn't matter.
08-26-2010, 12:59 PM   #200
Blue's Avatar
QuoteOriginally posted by Spongefingers Quote
Actually Nesster's statement is more accurate than you give it credit. First off, Pentax does maintain infinity focus with the authentic Pentax adapter and it does it at the 45.46 registration distance. However, Canon can't use FD and FL glass with a couple of minor exceptions making reverse compatible for canon glass very small. I have the EOS-FD macro adapter that allows the use of the macro lenses and the FD bellows on EOS bodies. There is a related adapter that works on some lenses. However, these were made in limited supply and are often very expensive when found. I want even get into the metering issues but Pentax is very straightforward with the m42 lenses. Pentax's current bodies can use 98% of all vintage Pentax glass since 1957. Canon is at less than 1%.
08-26-2010, 08:55 PM   #201
bbluesman's Avatar
Still really loving my A. Schacht Travenar 90mm 2.8. Would love to pick up an old Tak or some other German glass. Here is recent image. I also love NIK software for processing.
Self Propelled
09-05-2010, 12:55 PM   #202
Soligor Tele-Auto 135mm/2.8, f2.8
09-08-2010, 02:09 AM   #203
georgweb's Avatar
Wojtek, great pictures and I really like the boy portrait. He really pops out of the picture although there is no sun in the picture. The sunlit picture of the red berries is great also imo. Are all these pics from the Soligor ?
Here's a macro shot from a cheap plastic barrel lens, which you can also find with the 'Panorama' label. If it is fogged up a little, you can clean it from the front easily (for the tinkerer that is). It has a dedicated Aperture cable release connection, should work on bellows.
M42 MC Enna Macro Ennalyt 3.5/28, minimum focus distance without bellows on K100D + tripod, 5sek.
09-08-2010, 12:57 PM   #204
Dziękuję!Tak, wszystkie zdjęcia z Soligor Tele-Auto 135/2.8.Wszystko z Soligor.
09-12-2010, 01:44 PM   #205
Steinback's Avatar
105mm Telesar enlarger lens on Asahi Pentax M42 bellows out in the garden.
09-13-2010, 01:40 AM   #206
xjjohnno's Avatar
Isco Gottingen Berolina Westromat 35mm f2.8 at various apertures which I'm not going to try to remember the order of use.
[IMGWIDELEFT]http://www.xjgarage.org/photos/september2010/slides/PICT0360.JPG[/IMGWIDELEFT]
[IMGWIDELEFT]http://www.xjgarage.org/photos/september2010/slides/PICT0389.JPG[/IMGWIDELEFT]
[IMGWIDELEFT]http://www.xjgarage.org/photos/september2010/slides/PICT0420.JPG[/IMGWIDELEFT]
[IMGWIDEleft]http://www.xjgarage.org/photos/september2010/slides/PICT0411.JPG[/IMGWIDELEFT]
09-13-2010, 03:57 AM   #207
Arjay Bee's Avatar
German made M42 on Spotties
09-13-2010, 05:11 AM   #208
georgweb's Avatar
Quite something you got there Arjay.
09-15-2010, 03:39 PM   #209
Steinback's Avatar
More Telesar 105mm enlarger lens on bellows:
09-15-2010, 08:52 PM   #210
Steinback's Avatar
And a little bit closer:
crew, k-mount, m42, pentax lens, slr lens
Waiting for Crew spartan Monthly Photo Contests 0 08-31-2010 06:04 PM
Merry Christmas from Sailor and Crew Sailor Post Your Photos! 4 12-23-2008 02:08 PM
Another weekend of Crew racing reeftool Post Your Photos! 2 04-28-2008 06:49 AM
Crew races reeftool Post Your Photos! 0 04-23-2008 07:37 AM
The Whole Crew benjikan Pentax News and Rumors 3 05-31-2007 10:23 PM
All times are GMT -7. The time now is 08:57 AM. | See also: NikonForums.com, part of our network of photo forums!
