Originally posted by Ben_Edict The only drawback being, that there is no aperture. I even like the Crayford focusers, which are fairly standard on most scopes, more than the helicoids on photo lenses. Cray fords are just faster and quite as good.
Ben
Ben,
Aperture:
As a practical matter it does not make as much difference as you might think. When photographing birds you are often shooting under a dark forest canopy or deeply shaded brush. The result is that even if you are shooting with your $10000 f/5.6 800mm Canon where will aperture be set? - wide open or very close to it. Under these conditions, which are common in wildlife photography, your $10000 glass becomes a fixed aperture glass anyway. As a wide open fixed aperture glass a high quality scope has a distinct advantage. After all it is optimized for it's maximum clear aperture unlike a photo lens.
Crayfords:
Crayford's are even faster than you might think under real world conditions. Typically I shot very small fast moving nervous birds. This requires I shoot at a distance of under 40 feet. So the bird may be at 35 feet one moment and 20 feet the next. What I do is set the drag on the crayford very light. Thus a light tug on the camera body and the crayford acts as a very fast draw tube and brings the scope into close focus very quickly while I still can fine focus with the knobs if needed.
Under certain conditions I go even further and add a variable eyepiece projection adapter. This gives me an additional 40mm of focus, if needed, and brings me as close as 10 feet. I can use the additional 40mm of focus or not so it does not interfere with focus at infinity. 10 feet at 15x gives you near macro performance. Try using a conventional telephoto from macro to infinity and still maintain a fast focus throughout the entire range.
My apologies to the OP for getting off topic. I have a cold right now with too much time on my hands.
1 variable eyepiece projection adapter
2. Shot taken using above at about 12 feet
