Originally posted by IronWolf Hey All, I've been starting to really look into lenses (perhaps a little LBA haha), and I've had a post on here about a good wide angle. That led me into some other discussions and thoughts. I did some reading and saw a recommendation of good setup to start with, so I was curious what every one thinks.
For the time being you can put money aside (or if you really want to include a price for performance lens feel free).
The setup I saw would be something like this:
12-24mm f4
50mm f1.4
50-135mm DA* f.28
And then grow the needed lenses from there. I realize there is a gap between 24 and 50, but that can be made up by moving the feet I think?
Just curious what your thoughts are on this setup, or what you would think a good "ideal" setup would be. Seems like the 50-135 is getting rave reviews, and is almost too good to pass up.
Right now I have 2 lenses: 50mm f1.4, and an Old Pentax SMC 135mm f.35 prime (My dad bought this in the late 70's).
So anyways, lets here what you all think is a great starting setup!
I hope to shoot landscapes/architecture, all the way to birds (which I can get fairly close to them as they are at bird feeders maybe 20 feet away).
Thanks for your thoughts! Remember this can be an ideal (go all DA* if you really want haha.)
you have comitted the ultimate sin. You have asked a question that will generate at least one response from each forum member, because I'm sure they all consier their setup to be
IDEAL
I will approach this differently, I won't tell you my setup, there is no need because,
a) its mine not yours
b) its been posted many times already.
What I recommend is that you need to consider ultimately going for a range from 10mm to about 200mm, with some way to get 400mm for wild life if you are interested.
there are 23 million pentax lenses out there already (not counting 3rd party), so I'll let you imagine how many combinations are possible.
Things to consider
- if you are not really interested in wild life you can usually drop the need to go to 400mm
- wild life (or not) may also make you decide about whether 200mm or 135 is long enough.
- you need to consider some low light capability, with at least one lens faster than F2.8
- while not absolute, it is very nice to have as much of the 10-135/200 range at F2.8
- ultra wide (10-12mm) is great for travel and archetecture but not an absolute for landscapes
- do you still shoot film or have a full frame film camera? do the lenses need to work on it?
ALl of these things impact what you get, and I'm sure there are more. What I can recommend is that before replacing your kit lens, look at extending the range of lenses first. Only replace the kit lens if you find you need faster, sharper, etc... don't throw it away just because someone else says buy this
edit note, you already have some components of what you need.
plan out a map of what you think would be good and post that, looking for comments from others as to the pro's and con's
