02-17-2009, 09:47 PM - 1 Like   #1
enoxatnep's Avatar
DA 12-24 and filters: tough questions
I'm not trying to duplicate the "Polarizer for DA12-24" thread started earlier today, I just have more specific questions about my situation.
Anyhow, I too want a polarizer for my 12-24 (77 mm size), but I eventually also want to use ND grad filters, up to 2 at a time, along with the polarizer for certain situations. So I realize that if I buy a screw-on polarizer, to use the ND grads I would then need to attach an adapter ring to it in order to attach a Cokin or Lee filter holder in order to insert the ND grad filter(s), am I correct?
So here are my other questions:
- Using such a combination, at which focal length would vignetting disappear?
- Could I get away with a Cokin P holder for the ND grads, or should I get the Cokin Z-Pro or Lee holder instead? (I don't want to spend extra for the 4x6 filters, but I will if it means I can shoot at a lot wider focal length without vignetting.)
- Which of these systems allows you to place the ND grads right up against the lens (or polarizer) in order to reduce vignetting and light refraction?
cokin, filters, grad, grads, holder, k-mount, lee, length, pentax lens, polarizer, questions, slr lens
Nature Tough times volley Post Your Photos! 15 01-18-2010 12:41 PM
Thing's are Tough All Over Fl_Gulfer General Talk 31 11-23-2009 10:55 PM
This is tough. Mallee Boy General Talk 13 05-24-2009 04:30 AM
I may not be tough enough... madisonphotogrl Photographic Technique 37 03-23-2008 05:59 PM
Self Portrait the tough way paden501 Post Your Photos! 1 02-08-2008 05:18 AM
All times are GMT -7. The time now is 05:37 PM. | See also: NikonForums.com, part of our network of photo forums!
