02-19-2009, 10:11 AM   #1
scatron's Avatar
Indoor sports shooting on a budget
Sure, if money were no object, I get the DA 200mm f/2.8 ($856 on Amazon) or the DA 50-135mm f/2.8 ($708).
I've been using a Hanimex 200mm f/3.5 with uneven results:
Flickr: My stuff tagged with Hanimex 200mm f/3.5
Some examples:
200mm worked ok here:
But was a little tight here (and was hard to MF when they were moving around more)
Also, 200 mm is too tight if sitting on the sidelines of a gymnasium for kids' sports.
First preference would be a fast auto-focus zoom in the (approximately) 50-250 range for under $400. Does such a thing exist?
Second preference would be a manual-focus zoom.
Third - a shorter (maybe 100-150mm?) fast prime.
Any suggestions?
02-19-2009, 10:26 AM   #2
Blue's Avatar
In that case and based on the price range, consider either the Tamron or Sigma
70-200mm f2.8 AF lens.
02-19-2009, 11:04 AM   #3
scatron's Avatar
These are $600-700 at Amazon. Are they under $400 somewhere else?
02-19-2009, 11:13 AM   #4
Canada_Rockies's Avatar
I would seriously consider a 100/2.8. M/K versions are not overly expensive. I tend to use manual exposure for indoor shooting anyway - the light is tricky. For basketball I meter the floor and set it and forget it. For hockey I meter the ice and add two stops.
02-19-2009, 12:00 PM   #5
PEG Moderator
Kerrowdown's Avatar
I only use fast manual primes for this type of photography, that extra stop or two can really make a difference, certainly in terms of brighter viewfinder so you can see whats going on.
02-19-2009, 01:07 PM   #6
Blue's Avatar
QuoteOriginally posted by scatron Quote
Not that I know of, but neither are either of the DA* lenses in your OP.
Edit: If you know of a source of DA* 200mm lenses for under $400, I'd like to know!
02-19-2009, 01:12 PM   #7
Blue's Avatar
One of the things to keep in mind when photographing indoor sporting events is the lighting. There are several types of lighting that may be encountered from sodium vapor, mercury vapor, florescent (many variations), halogen etc. This can effect your image dramatically if not accounted for.
02-19-2009, 01:26 PM   #8
dave9t5's Avatar
Spend the $400 on a second body and/or short lens. Presumably you have either a short prime (in the 30~50mm range) or a short zoom already (most people have one or the other or both). When the action is in your end of the court shoot with the body with the short-lens. when the action is in the far-end of the court, shoot with your 200mm.
A prime will be faster but one advantage to a short zoom is that when the action is in your end of the court, the working distance (focal length) changes relatively suddenly. At the far-end of the court, the working distance is pretty fixed.
Another advantage of a short zoom is an AF one is relatively cheap, and the AF will probably benefit you more when the action is in your face.
You could find a K10D for $400, or a K100D Super + zoom for similar. An FA28-70/4 is relatively fast.
(It seems you can live with the f/3.5 of your current 200mm...)
Dave
02-19-2009, 01:27 PM   #9
scatron's Avatar
Those were examples if money were no object.
You missed this part:
02-19-2009, 02:29 PM   #10
PentaxPoke's Avatar
I shoot a lot of basketball. Mostly with primes ( 35mm, 50mm, 70mm). The only zoom I have used regularly is the 50-135 but I still like the primes better because they focus faster, and are lighter so I can be more mobile. Also with a good quality prime, even if your focal length is not long enough, you can crop and yield excellent results.
So with your stated budget and goals, I am with Dave that primes are the way to go. You are already getting some excellent shots with your 200.
I also find that the Katzeye split screen helps me a lot with focusing because with so much action going on, you can't always trust the AF to focus the way you want (Link): https://www.pentaxforums.com/forums/pentax-dslr-discussion/46978-my-k20d-katz...-pictures.html
DA 70/f2.4 cropped
02-19-2009, 02:29 PM   #11
Blue's Avatar
You are correct, I missed that. That price range would limit you to some 2.8 manual lenses like the Tamron Adaptall 2 SP 80-200mm f2.8 lens. This lens can be found for <400. There is also a Tokina lens in the same FL and f2.8.
Remember that when picking a lens you can pick 2 of 3 only: Good, fast, cheap.
02-19-2009, 02:36 PM   #12
SouthShoreRob
Guest
The FA 50 F1.4 will do an excellent job for you. I have also been very impressed with how well my new DA 55-300 is handling sports. Given the fact it's paired to my K20, I can boost the ISO to 2000-3200 and overcome it's slow F4 to F5.8 aperture. See examples of my recent hockey pics by following the link in my signature.
Rob
02-19-2009, 02:40 PM   #13
Blue's Avatar
QuoteOriginally posted by SouthShoreRob Quote
Rob
I suggested some lighting issues above but didn't get into the ISO because of his camera body. Otherwise, he could do that with his Hanimex and see how it goes.
02-19-2009, 02:52 PM   #14
Under $400
- Manual focus 80-200 f2.8 Tokina at-x (around $200)
- Manual Focus 60-125 F2.8 Tokina at-x (i watched one on ebay go for about$100)
https://www.pentaxforums.com/forums/photographers-marketplace/42159-tokina-x-...-f-2-8-pk.html
Combine one of these with a split-focusing screen and your good to go. I believe these are both manual aperture which may not be the most desirable.
02-19-2009, 03:03 PM   #15
PentaxPoke's Avatar
QuoteOriginally posted by reknelb Quote
Under $400
These look like really good value zoom options. The nice thing about shooting basketball is that the lighting does not change so you can easily shoot M, and set the ISO, aperture, and shutter speed once, and you are done for the entire game. That way, your exposures are consistent for the entire game and you don't get the wild swings in exposure you get by alternately pointing the camera at the dark and light colored jerseys. The only thing you really have to worry about is focus. I often turn off the AF and use MF for games.
200mm, da, f/2.8, f/3.5, hanimex, k-mount, pentax lens, preference, slr lens, sports
Best telephoto lense for indoor sports? plucci Troubleshooting and Beginner Help 20 02-03-2010 12:20 PM
2.8 Lens for Indoor Sports without Flash? joelovotti Pentax SLR Lens Discussion 7 08-13-2008 07:36 PM
Indoor sports photography how to? sglj3 Pentax DSLR Discussion 9 04-24-2008 11:32 PM
Prime lens for Indoor sports? Falcons Pentax SLR Lens Discussion 4 08-01-2007 05:35 AM
Better lens for indoor sports - or maybe not? WMBP Pentax SLR Lens Discussion 6 04-23-2007 03:07 AM
All times are GMT -7. The time now is 04:12 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
