02-19-2009, 06:33 PM   #1
Paulypentax's Avatar
Tamron Adaptall Lens Question
Hey fellow Pentaxians,
I just put one of my old Tamron Adaptall lenses on my K10d. It is the 35-80mm 2.8-3.8 SP CF. I was using in Apature Prioraty mode. I set the f stop to 2.8 and I was able to shoot at 80mm at 2.8. Why didn't it move to 3.8? Not that I'm conplaining, just curiouse. Thanks.
02-19-2009, 06:38 PM   #2
QuoteOriginally posted by Paulypentax Quote
That is a good question. I suspect that there is no mechanism to communicate the variable max aperture to the camera body. I suspect that this is even the case with the PKA adapter. (Definitely true for the PK adapter...)
02-19-2009, 06:46 PM   #3
Lowell Goudge's Avatar
on the Adaptall mounts for PKA there is an internal switch that is set by the two "tabs" on the mount to the correct encoded value on the apature pins to define the lens for maximum and minimum apature.
For variable apature zooms, especially early ones, there was no compensation for focal length and the impact on apature. This came about int he early 1990's
The cameras at the time did not care, because they used the light on the sensor to determine exposure, and these meters were accurate.
It would not matter today, except the desire for super bright viewfinders has led to viewing screens that produce non linear metering (specifcially K10D and K20D). These bodies use actual apature to correct for metering non linearities.
adaptall, k-mount, pentax lens, slr lens, tamron, tamron adaptall lens
Tamron Adaptall question binh.nguyen Troubleshooting and Beginner Help 2 08-29-2010 04:27 PM
Tamron Adaptall question Glacian22 Pentax SLR Lens Discussion 10 07-15-2010 05:42 PM
Tamron Adaptall 2 question iClick Pentax SLR Lens Discussion 6 06-05-2010 09:57 PM
Tamron Adaptall-2 Mount Question rayallen Pentax SLR Lens Discussion 7 04-28-2009 04:37 PM
All times are GMT -7. The time now is 11:29 PM. | See also: NikonForums.com, part of our network of photo forums!
