Originally posted by Class A I stumbled about this comment as well. AFAIC, the foreground bokeh of the DA55 looks clearly better.
In what way?
Please keep in mind that both rows do not look exactly the same because they are produced by turning the focus ring in small steps.
This results in slight differences because I did not get the same position for both always. The second column is an example.
What you can deduce from the experiment are two things:
1. The color rendition is the same (foreground red, background green).
2. The brightness distribution is the same (roughly Gaussian in the foreground, bright ring in the background.
In real life shots you will not see a difference in bokeh IMO.
I haven't tested coma.
Perhaps the DA55 is better here, due to better correction.
Interestingly the rear lens diameter of the DA is larger than the FA: 32 - 28 mm.
