Originally posted by Just1MoreDave
The aperture ring must be set in the A position, otherwise the camera thinks it's a non-A lens. That sounds like what has happened here.
The lens that mounted on the converter but not your camera may have an extended light shield that's running into parts of the newer camera mount. The light shield is next to the aperture lever. It will look much bigger than one on a Pentax lens. It can be removed and filed down so it's the same shape as a Pentax lens.
Thank you!... Thought I checked that out... Hummm... OK will check out on Monday and if they meter I'll get them and play! The Macro function on the 50 sounds neat.
