Hin,
I have the 70-150/3.5 of the same era and get f/3.5 as the maximum aperture with the P/KA adapter. My adapter was always a little flaky (often F---) until I scraped the surfaces of the two flat-faced "donut" contacts with the tip of an Exacto knife.
Regarding your issue...Are both of the "tabs" engaged properly on the aperture ring and is the mount fully engaged at the end of its stop with the release tab popped up? It is my understanding that the position of the left tab (base towards you, green dot on top) communicates the position of the aperture ring. The position of the right tab is supposed to index to the maximum aperture.
I am not exactly sure how the P/KA adapter works. Using Mark Roberts' pin guide, it appears that the "A" pin is the spring-loaded ball in-between the other two black "donut" connectors.
Edit..I think I am reading this wrong...There is nothing at the #1 position, a black insulator at the #2 position, a switchable contact at the #3 and #4 positions, and nothing at the #5 position. The P/KA mount pre-dates the data pin, so that should be of no concern. There are also the three small divots on the mount flange and two more divots on the inner step flange immediately inward from positions #3 and #4. One of the divots is in-between the #1 and data pin, but the others don't correspond to anything on the body. (I think the divots are manufacturing index marks.)
A quick look at Roberts' chart and it is apparent that you can't account for known Adaptall-2 lenses since all would have the pattern mask of 10x*x1.
end wrong stuff
It makes me think that Pentax may have supported more than one version of the "A" lens interface. I think I may spend some time with my ohm meter and the P/KA mount...
Edit...Start of better stuff...added after a session with the multimeter
I think I misread the contact spacing. How about
- insulator at #1
- switchable at #2
- nothing at #3
- nothing at #4
- switchable at #5
Pattern mask = 0x1*1x
Here is the measured pattern for my two lenses with the P/KA adapter assuming the above mask
28/2.5 : 011*11
70-150/3.5 : 001*11
These fit Roberts' chart (
see here). Unfortunately the chart does not include lenses having a minimum aperture of f/22 and a maximum of f/4.5 and narrower.
end better stuff
(My brain is full...may I be excused...)
