04-03-2007, 10:02 AM   #16
QuoteOriginally posted by Finn Quote
You mean you don't like all the snarky condescension on the DPR forums?
Like it? Ahh, too much. But you know what they say....."Too much of anything isn't good for you". And that's why I don't hang out there .
This forum, here, is comprised of the caliber of people & attitudes that I cotton to. And that's the real deal .
04-03-2007, 10:06 AM   #17
borno's Avatar
hey nathan,
one thing to check, make sure the aperture ring is all the way over to a with the little button or the contact on the lens mount won't connect and the camera will think it is a manual lens which needs "allow aperture ring use" set in the menu. It will work best in "a".
tom
04-03-2007, 10:42 AM   #18
benjikan's Avatar
Solution..Perhaps.
First off, not to insult your intelligence, I imagine you know you "must" keep it in "A" mode on the lens. Secondly. It is often as simple as taking the lens off of the camera and replacing it back on to the unit with a very solid twist to lock. Re-start the camera and it should be fine. This has happened a couple of times with a couple of my lenses. I re-mounted them and they worked perfectly. I think people are a bit concerned about snapping them in to place too aggressively. It really has to click soundly in to the housing.
Ben
k-mount, lens, pentax lens, slr lens
Possible K-7 tethered solution ahead! tigrebleu Pentax DSLR Discussion 0 10-26-2009 06:03 PM
one lens solution pmountford Pentax SLR Lens Discussion 51 10-17-2009 06:32 AM
Excellent SD backup solution jots Pentax Camera and Field Accessories 14 04-02-2009 02:41 PM
A better custom WB solution? joefru Pentax DSLR Discussion 26 06-25-2008 12:45 PM
RH - my solution Canada_Rockies General Talk 8 03-18-2008 08:40 PM
All times are GMT -7. The time now is 02:05 AM. | See also: NikonForums.com, part of our network of photo forums!
