Originally posted by egordon99 Tell us more about your low-light shots that aren't coming out better than your 18-200mm? Assuming your 18-200mm is about f/4 or so at 50mm, f/1.4 gets you THREE more stops of light. If your low lights shots aren't coming out better, you're doing something wrong. Or there is something you don't understand about exposure settings.
Hi again (and, thanks again).
You, more than likely, hit the nail right on its head with your last sentence in the above quote. User error is probably the reason behind this whole issue that I am faced with.
Last night, I went outside to shot a couple of shots under the street lights - figuring that such a setting would qualify for my 'low-light' attempts. Only a couple of my shots came out enough to show anything at all, while most of them only caused the camera's LCD screen to remain dark - with the 'Delete' indicator at the lower left side.
I had really wanted to get to shooting some
candlelight shots, but knew (from the above shooting situation) that something had to be altered about the way that I was doing things.
I have seen clear & beautiful evidence, here, of what this lens is capable of. So, it is just a matter (I am now sure) of learning much, MUCH more about exposure settings.
