04-03-2007, 10:26 AM   #1
Photochop's Avatar
Why long range lenses for landscape shots?
I've read several posts on a variety of forums about using a longer range lens...say 77mm and up for landscape shots and I'm a bit confused as to why so I'd like to hear your take on this. Do you prefer wide angle lenses or long lenses for landscape shots and why?
04-03-2007, 10:37 AM   #2
Finn's Avatar
Depends, but generally I like a shorter lens because there is less flattening of the perspective, and generally greater clarity because when you're closer to your subject the light doesn't have to travel through so much air (and dust and smog and pollen and...) on the way to the camera.
Then again, using a wide angle lens can lead to the temptation of photographing broad vistas that lack a point of focus -- deadly!!!
Sometimes you just want to focus on a smaller piece of the landscape you're looking at, so a tele can be of great use as well. I keep both in my bag at all times, just in case.
04-03-2007, 11:19 AM   #3
Sometimes, ultra-wide angles either cover too much or just don't magnify enough to make a good photo.
Here are a few examples, taken with the A* 200mm:
You can see what I mean by comparing these two shots:
04-03-2007, 11:29 AM   #4
Photochop's Avatar
I see! Thanks for the help guys I've used zoom lenses for landscape shots like the ones you've demonstrated Mo but the way I interpreted the threads I read was that if you shot the exact same scene, same composition, crop etc.. the longer lens would have an advantage to the wide lens and I wasn't sure why.
Thanks again Finn and Mo, I appreciate your clarification.
04-03-2007, 06:26 PM   #5
Phazed's Avatar
I took this picture this past weekend, an example of a really wide landscape 10mm if I remember correctly.
04-03-2007, 07:09 PM   #6
Photochop's Avatar
Nice! Looks like a picture out of a science fiction novel. I have the Zenitar but I lust for the Pentax 10-17.
k-mount, landscape, lenses, pentax lens, range, shots, slr lens
Landscape Some landscape shots around Geelong Christopher M.W.T Post Your Photos! 7 10-06-2010 01:48 AM
HowTo long range telephoto shots falconeye Photographic Technique 3 04-08-2010 04:32 AM
People Tamron Long Range Fun tokyoso Post Your Photos! 1 02-25-2010 08:34 AM
Long range lens suggestion vizjerei Pentax SLR Lens Discussion 26 10-27-2008 05:49 PM
Cheap, long-range telephoto lenses any good (how about prime ones)? bjsmith Pentax SLR Lens Discussion 35 06-21-2007 10:53 AM
All times are GMT -7. The time now is 03:48 AM. | See also: NikonForums.com, part of our network of photo forums!
