03-08-2009, 12:09 AM   #1
Slippage/Slipping on FOCUS ring? 50mm SMC 1.7
I bought my first 50mm SMC 1.7 off ebay.
The focus ring slips, especially once it reaches the ends of close and infinity focus.
When it reaches the end, it can still keep spinning instead of stopping.
I assume this is not supposed to happen?
Also... should I get the 50mm SMC 1.4? Or be happy with a 1.7?
Thanks!
03-08-2009, 12:15 AM   #2
QuoteOriginally posted by PentaxForums-User Quote
It should stop once it reaches either end. It sounds like yours is defective.
Thanks!
You may want to give SMC-A f/1.4 a try. SMC-A lenses work in all modes and allow you to use most of the camera's features, when their aperture ring is set to A(uto). Good luck.
03-08-2009, 12:48 AM   #3
Steinback's Avatar
Is it just the rubber grip that is slipping? I'm not sure how they're attached originally (glue maybe?) but I've seen lenses where the rubber grip turns freely if the lens is at one of its stops. A bit annoying, but if that's the case the rest of the lens should function fine.
03-08-2009, 01:11 AM   #4
frank's Avatar
By the design of the M/A 50 lenses, I don't think you can keep turning the focus ring when it hits the limites (45cm or infinity), otherwise the whole lens group might fall out of the barrel
Maybe it's the rubber ring (which covers the focus ring) that keeps turning as Steinback said above? If that's the case, just glue it to the focus ring w/ a couple of drops of super glue
03-08-2009, 09:55 AM   #5
Just1MoreDave's Avatar
QuoteOriginally posted by frank Quote
There's a screw that stops the focus ring. It's just above the orange diamond:
That's the most likely problem and solution. If the lens is still focusing as you look through the viewfinder, at the correct distances more or less, then it's the grip. If you can move the focus ring and the distance markings without changing the focus, it's loose focus ring attachment screws. In that case, the ring will still hit the stop screw.
Here is the focus ring and the rubber grip from another M lens.
50mm, focus, k-mount, pentax lens, slr lens, smc
SMC Pentax-M f1.4 50mm loose front ring? theperception2008 Pentax SLR Lens Discussion 6 05-04-2011 08:06 PM
A-50mm 1:1.7 focus ring off kilter, HELP! logic14 Pentax SLR Lens Discussion 6 10-18-2009 10:48 AM
Focus ring question (DA* 50~135mm, DA*16~50mm) bingsean Pentax SLR Lens Discussion 6 03-20-2009 11:20 AM
For Sale - Sold: SMC Takumar 50mm F/1.4 (later model w/ rubber ring) barbosas Sold Items 16 04-08-2008 03:09 AM
For Sale - Sold: FS: SMC Pentax-A 50mm f/2 lens with reversal ring and filter drabina Sold Items 0 03-11-2008 06:36 AM
All times are GMT -7. The time now is 02:44 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
