Originally posted by Jimfear I wonder what brakes first though, does the metal on the lens bend or break or does the whole mount come of the camera? Any thoughts on this?
I doubt anything will bend, possibly that the mount on the lens (in this case the adapter) will get grinded down so that it does not fit anymore. The mount on the camera is very firmly stuck in the entire chassis inside the camera which is steel and will not break for such small weights. You could probably mount a hook in it and hang in it with your bodyweight.
I also doubt that the m42 thread will break for such little weight. So the weak link would be the flanges on the adapter. Which on the genuine (cant speak for others) seem strong enough to hold for quite a weight. Only if the edges on it was grinded down thru wear, I think it would be a risk for the lens. But hopefully, if that happens you will notice it far in advance.
So, just check the adapter and m42 threads now and then and I am sure youll be fine. And the old takumars are tanks, if you manage by force to bend the barrel of a Takumar, I will be impressed of your muscle mass.
