I have a few questions, but first the background. I am testing the Tamron 90mm Macro f 2.8 with & without the Tamron 1.4xPz-Af MC4 teleconverter.
To setup a fair test comparison, I am striving to equalize the variables. I find it easy to adjust for the %40 increase in focal length with the teleconverter by simply measuring distances and adjusting accordingly. Through this methodology, I can get close to precise images, with respect to size. Also, it is easy to equalize the light since it is dark out and I have a constant supply of incandescent lighting. The subject never moves throughout the test and is parallel to the sensor plane. However, other variables are not so easy to equalize and I am looking for help,
Firstly, I understand the teleconverter subtracts one stop of light, at least in theory. So my first question is, when I make direct comparisons with apertures, what do I compare to what? For example, the shot without the tele @ 2.8--does that get compared to the shot with the tele @ 2.8--which means f4, since a stop of light is lost? Or should I compare a shot @ f4 without the tele to a shot @ f2.8 with the tele?
Secondly, I am looking at the one stop loss in light due to using the tele and am confused. If there is a 1 stop loss in light then a shot @ f2.8 & 1/6th without the tele, should be a closely identical exposure to f 2.8 & 1/3rd with the tele. But when I compare these two exposures, the one with the tele is significantly more overexposed than the one without the tele--leading me to believe there is less than a loss of one stop when using the tele.
I tried comparing exposures, in this manner, at other apertures and got the same results. For example. a shot @ f5.6 & .3 without the tele, should equal a shot @ f5.6 & .6 with the tele. But again. comparing these 2 images the tele one was significantly overexposed. To get comparable exposures @ 5.6, with & without tele, I had to shoot @ .3secs & .5secs, respectively. To demonstrate this complicated (at least to me) phenomenon, I have 2 crops below. The first one was shot without the tele @ 5.6 & .3secs. The second one with the tele was shot @ 5.6 & .5sec. Even more perplexing, the one shot with the tele is a bit more exposed than the one without the tele.
I am looking for all the help I can get with this one--thanks.
