03-15-2009, 02:42 PM   #1
Boring 100% center crops of K20D + DA 17-70 SDM f/4
I have neither the time nor the patience to do a thorough test, nor do I have a USAF resolution test chart handy, but here's something for all fellow casual pixel peepers. My observation was that the results are pretty much indistinguishable at f/4 (wide open) and f/5.6. The only difference could be that in one case, the lens is focused spot on and in the other it's not--I refocused before each shot. I also tested for front and back focusing and didn't notice anything...well...noticeable with my inexact noticing.
Both are at 70mm. Now, now, keep in mind, it's a zoom. One of these is f/4. Another is f/5.6. (It may surprise you which is which.) I used a (rather unsteady) tripod, cable switch, mirror lockup, ISO100 etc. The exposures were relatively long (~1/3s).
EDIT: I removed the crops: I'm thinking of redoing this with black on white text...So do ignore.
EDIT2: This testing obsession can easily get out of hand: I think I may end up with an ISO resolution test chart.
For my own good, I think I'm going to take a break. So if anybody has stumbled upon this post by accident, for now, I must direct you to photozone's test which unfortunately is done on a K10D, not a K20D.
EDIT3: If you came here by accident, here's a less boring 100% center crop, K20D, f/4, 70mm.
accident, chart, crops, da 17-70 sdm, f/4, k-mount, k20d, pentax lens, slr lens, test
Crops? kewpie-o Digital Processing, Software, and Printing 7 06-20-2009 08:28 PM
online tool for generating 100% crops with exif info walter Digital Processing, Software, and Printing 7 10-26-2008 03:37 PM
AF problems with SDM lenses on K20D? tcom Pentax DSLR Discussion 19 07-18-2008 07:55 AM
DA*300 Sample 100% Crops (Some with TCs) channeler Pentax SLR Lens Discussion 29 05-06-2008 03:16 PM
Crops?? jshurak Photo Critique 20 12-29-2007 01:06 AM
All times are GMT -7. The time now is 03:33 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
