03-18-2009, 10:05 AM   #1
wide angle or small zoom?
Hi,
Basically I am a bit torn between buying either a wide angle like the sigma 10-20 or a small zoom ie 16-50 as per the pentax . It seems the latter is more convenient but I would like a wider angle ... currently I have a 28-200 and a straight 50mm.
Basically is 16mm wide enough and good enough quality in comparison to a dedicated wide angle.
Secondly, if I go for a small zoom I am a bit confused as to which is best as there appear to be a lot ie sigma 17-70, tamron and then the new PENTAX 16-50 mm F 2,8 ED AL SDM.
Its a bit of an open question but any advice would be welcome.
thanks
03-18-2009, 10:38 AM   #2
alohadave's Avatar
You are comparing two different categories, super wide and wide-normal.
I use my 16-45 95% of the time. I use my 10-20 when I want to get the super-wide effect, and when I want to distort the subject and get super close.
03-18-2009, 11:44 AM   #3
Marc Sabatella's Avatar
If you're accustmed to 28mm on a Pentax DSLR as being your widest, then 16mm is indeed a *lot* wider. Whether it's wide "enough" is another matter. Would be for me 99% of the time, but clearly, it isn't for everyone or no one would make a 10-20. The 16-50 also has the advantage of being constant f/2.8, making it much more useful indoors than your 28-200.
BTW, no ure what you mean by a "small zoom", but none of the lenses you mention are particularly small in size. "standard zoom" or "normal zoom" or "wide - short telephoto" seems like phrases that would more accurately describe what you re asking about (eg, the 16-50, 17-70).
03-18-2009, 12:07 PM   #4
thanks, I wasn't sure of the correct term in fact.
I am comparing the two types as I can't really afford two lenses but I know want something that can go wide(r) than I have. If its going to be in use 90+% then it seems a better investment.
Now which one ...
thanks
03-18-2009, 07:11 PM   #5
SpecialK's Avatar
The 12-24 is highly regarded and is a very useful range.
03-18-2009, 07:16 PM   #6
QuoteOriginally posted by nodretep Quote
Hi,
thanks
Avoid variable aperture zooms. You may find shots at around 10-15 too gimmicky and odd looking for your taste. So find samples first.
angle, bit, ie, k-mount, pentax, pentax lens, sigma, slr lens
Which wide angle zoom? Bossy Pentax SLR Lens Discussion 4 08-29-2010 12:42 PM
Wide-angle Prime OR Zoom kacansas03 Pentax SLR Lens Discussion 36 06-10-2010 11:07 AM
FF wide angle zoom? Gooshin Pentax SLR Lens Discussion 9 12-16-2008 12:13 PM
which wide angle zoom karlwr Pentax DSLR Discussion 8 07-09-2008 07:37 PM
Recommendations for wide angle zoom Papersniper Pentax SLR Lens Discussion 9 11-06-2007 01:54 AM
All times are GMT -7. The time now is 01:52 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
