I was trolling ebay again, looking for the cheap lenses.
I saw this
one and looked a bit, and then took a chance on it.
I could not make out any numbers on the image, the mount is obscured, but I found a Ricoh manual online and it specifically mentioned a K-Mount. I understand theremay be some sort of pin tht needs to be removed, so I hope someone can help if that is true.
I
hope that it is smilar to this
one but a 28mm.
So, now (assuming I can use this one) I have a kit lens, the Kiron made Vivitar 70-150mm (still in transit) and a Tokina 28mm (just purchased).
Anyone know anything about this lens?
