03-19-2009, 10:18 AM   #1
dcmsox2004's Avatar
storing lenses.. using dessicants ??
i'm trying to avoid fungus (not on me) on any stored lenses...
even though i store unused lenses in as low a humidity and temperature environment... i was wondering if using those little silica gel packets would be
of any benefit.... any other ideas....
03-19-2009, 10:22 AM   #2
dcmsox2004's Avatar
for example.........................
Silica Gel Desiccant Dry Packs 125 Grams Storage Camera - eBay (item 180324541111 end time Mar-30-09 08:14:05 PDT)
03-19-2009, 10:59 AM   #3
I'm not sure about the benefit of silica gel.
I don't store cameras and lenses in enclosed space. They are on open shelves attached to the walls of my study. They can collect dust, but I clean them periodically, and dust is much easier to handle.
With an open space, silica gel would help very little, if any.
Storing cameras and lenses in their cases, and/or in an enclosed space is asking for trouble, silica gel or no silica gel.
03-19-2009, 11:07 AM   #4
vizjerei's Avatar
I put mine in an air tight box, with silica gel pack.
The Air tight box is cheap from Korean supermarket, which their main purpose for storing Kim-Chi. I got a big air tight box which can put all my lens including 50-135 for only $6.99 Can.
03-19-2009, 11:10 AM   #5
dcmsox2004's Avatar
can you provide a pic of what your air lock box looks like, i've never heard of this...
thanks !!! dave m
also, how often do you change the silica gel pack (and where do u buy them)...
i also know there are different sizes of silica gel packs....
03-19-2009, 11:15 AM   #6
vizjerei's Avatar
QuoteOriginally posted by dcmsox2004 Quote
thanks !!! dave m
( read my last post also, i added some info of it )
I will take a pic of it when I got home, silica gel can be reused, you can mircowave them to get the water out of them.
How to reuse drying agents
03-19-2009, 11:27 AM   #7
rburgoss's Avatar
QuoteOriginally posted by vizjerei Quote
Note 1: Microwaving or heating by any other method, silica gel packs that are made from any type of plastic, WILL MELT THE PLASTIC making the silicagel unusable. Better to get enough silicagel packs, open them and transfer crystals to paper envelopes. Better if using cotton cloth type bag packets.
Not 2: Air tight containers = TUPPERWARE from any local supermarket.
03-19-2009, 11:31 AM   #8
dcmsox2004's Avatar
thanks.... i'll give my wife my order at her next party...
i did found another post in the forum.....
what would i do without my daily 'forum'............
simply the best......
03-19-2009, 11:40 AM   #9
vizjerei's Avatar
Thanks rburgoss. I have no idea about those brand name of storage :P
dcmsox2004: There is also another thing, which is dry cabinet with temperature control and stuff.. of course it cost $, they are quite a norm in Asia (Hong Kong and other cities) as it is humidite in summer.
03-19-2009, 11:57 AM   #10
RioRico's Avatar
I now live in high dry places, with lenses stored (maybe in loose cases or loose little cardboard boxes) in loose little Ikea CD cabinets. (Loose = nowhere near airtight.) When I lived in low moist places (SF, KC, NYC, LA) lenses & bodies & flashes etc resided in sealed Tupperware containers with silica gel. To dry the gel, follow directions to oven-bake, NEVER MICROWAVE! Nuking lenses & cams & flashes probably doesn't help them much, either.
03-19-2009, 07:21 PM   #11
StevenVH's Avatar
I was just contemplating this and searching the 'net recently. By googling for "dry box" I found everything from cheap Tupperware type containers to fishing/hunting boxes and dry bags to Pelican types to climate controlled boxes and cabinets.
I may go cheap and just get a plastic air tight bin of some sort, but I was tending toward getting something more useful like a Pelican case.
I already got some very nice aluminum, reusable silica packs from a coin dealer on fleabay.
hth
03-19-2009, 08:04 PM   #12
Ira
All you do to clean silica gel is run the faucet over it, regardless of the pak or pouch it's embedded on.
And a great thing to know:
The stuff removes moisture, so a nice amount of it in the proper pak is amazing to put in your refrigerator. It removes the moisture, which makes your fridge work a lot harder to maintain the same temp.
And because of less moisture, vegetables last A LOT longer.
03-19-2009, 08:16 PM   #13
mithrandir's Avatar
Another possibility is this item from Sportsman's Guide:
Remington Dehumidifier, Shooting Supplies, Remington at Sportsman's Guide
You can use it in a cabinet, safe, or other semi-sealed space.
03-19-2009, 08:48 PM   #14
StevenVH's Avatar
/snip
haha...never heard that before.
03-20-2009, 02:56 AM   #15
Tom S.'s Avatar
That may work to clean it, but unless you dry it out afterwards, you've just defeated it's purpose. Putting it in a warm oven will dry it out so it will again absorb moisture.
k-mount, pentax lens, slr lens
Storing your lenses HawaiianOnline Pentax SLR Lens Discussion 20 03-20-2014 06:45 PM
Storing lenses off body bfo Pentax SLR Lens Discussion 13 05-18-2010 09:15 AM
Storing lenses up or down? Kguru Pentax SLR Lens Discussion 40 08-18-2009 10:58 PM
Storing Camera/Lenses NothingInCommon Troubleshooting and Beginner Help 17 07-15-2009 09:09 AM
Storing Images atyab Photographic Technique 4 09-25-2008 06:02 PM
All times are GMT -7. The time now is 01:18 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
