03-25-2009, 08:20 PM   #16
creampuff's Avatar
Let's put it this way, my Pentax local agent doesn't use these so called focus charts to calibrate focus accuracy. Also the lighting used during the tests also plays a part.
03-26-2009, 04:22 AM   #17
schmik's Avatar
Creampuff, do have anything else to say on the subject?
So what does the Pentax local agent use? what kind of lighting and HOW does it affect the test?
mike
03-26-2009, 07:03 AM   #18
creampuff's Avatar
Daylight, graduated ruled scale.
Most of the time the issue is with the camera body.
That's the main reason I dumped the K10D for the K20D.
03-26-2009, 08:37 AM   #19
Marc Sabatella's Avatar
QuoteOriginally posted by schmik Quote
Yes, they are just crops. Here is the full image. Camera height relative to the test chart is not ideal in this test (it was in previous tests) but i don't think this matters too much.
You're probably right on the limit of how small you make that center line and still convince the center AF system to choose it. Have you seen the discussions about how big that center AF sensor really is? It's pretty big. As it is, on this posted shot, it's still seems entirely possible the camera could have chosen the scale above or below. Try shooting from a bit closer so the scales are well outside the range of the AF sensor. If in doubt about just how big the sensor is, perform the experiment I suggested elsewhere: try focusing on a black dot on a white piece of paper and see how far off center the camera will let you do that. You'll find it will happily focus on objects far above and below the red square.
04-03-2009, 02:06 AM   #20
schmik's Avatar
Woooo hooo!!! Got my replacement today and it is good. No backfocus and it's sharp wide open. Thank god for that. Now I can shoot away without stress. Here are a couple wide open.
cheers
mike
04-03-2009, 03:35 PM   #21
axl
congrats mike...
now ENJOY
BR
04-03-2009, 05:41 PM   #22
Igilligan
Guest
Hooti Hoo Mike
Glad to see you are in with the in crowd... that looks like a good one.
04-03-2009, 06:08 PM   #23
schmik's Avatar
The funny thing is how good the images look at home on the iMac monitor.... then resized and uploaded AND at work on some cheapo DELL monitor they may as well be shot with the kit lense
mike
04-03-2009, 07:07 PM   #24
ManuH's Avatar
I like this one too:
Jeffrey Friedl’s Blog Jeffrey’s Autofocus Test Chart
Try the 20% chart, it works well with Pentax. First, make sure the camera is unable to focus on the grey parts.
04-04-2009, 03:23 AM   #25
schmik's Avatar
Here's a couple from after work this afternoon.
cheers
mike
04-04-2009, 02:58 PM   #26
axl
nice ones schmik, I see you are enjoying the lens. There is a lot to enjoy on DA40...
BR
40mm, 50mm, bodies, body, f1.7, k-mount, k100d, lens, ltd, pentax lens, slr lens, test
Da 40mm f/2.8 Shutter-bug Pentax SLR Lens Discussion 87 09-27-2011 08:46 PM
which 40mm? pentax da 40 or Voigtlander Ultron 40mm f/2.0 SL-II dexmus Pentax SLR Lens Discussion 12 10-30-2009 07:26 PM
DA 40mm ltd blotzphoto Pentax SLR Lens Discussion 21 03-05-2009 07:31 PM
My new 40mm 2.8 ltd :) Taff Post Your Photos! 14 10-29-2008 04:29 AM
All times are GMT -7. The time now is 03:39 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
