Originally posted by muustuus Got the Kenko Pz-AF 1.5x Teleplus SHQ DG. Tested with DA*200 and sdm works fine, but it hunts a bit more with tc. You have to hold the lens very still to get focus. I did some quick tests and it doesn't look too bad. It's definitely giving some extra magnification. Have to test some more extreme situations.
plop.
Congrat
Your combo is actually 450mm in film day ( 200mm 1.5 x 1.5 crop factor). Once you get used to long lens, you be ok
You are sure that yours has got a DG there? Can you check
It should be like this
Daniel
