Returning to the OP's actual question:
Originally posted by amicah22 Any suggestions or ideas to make this lens more consistent
I've had the 10-20 for a while, and I'm reasonably confident I've got a good copy. One thing I've learned to do is this:
... Ensure that it focuses.
At extreme wide angles, the depth of field is so colossal that the camera (K10D in my case) often doesn't think it needs to refocus. You can reframe, point at something else, and it doesn't refocus. This leads in my experience to shots that look Ok on the LCD, but aren't quite sharp once you look at them properly.
I've found that if I consistently focus on something really close, before taking the next shot, it *has* to focus the next time, and gets it much better than if only a small adjustment is needed.
