Originally posted by Zeroset I'm still hearing ideas if anybody has any that haven't been mentioned yet, though.
Maybe drill two holes through the filter rim, 180º apart, easiest from the inside of the filter to the outside. Then stick a metal bar, possibly a really long nail, through both holes, and use the bar for leverage. It might be hard getting large enough holes for the bar within the filter rim. A similar alternative is to use a hacksaw to cut slots or notches in the filter rim 180º apart. Put a plastic bag around the lens first and seal it with a rubber band to keep metal shavings out of the lens. If this fails, you have a really ugly lens now.
Breaking the filter glass is possible, but always requires more force than you hope to apply. Using a glass cutter might help but commits you even further to removing the filter. If the filter glass is gone, the rim can remain.
You could sell the lens on eBay and say it has always been protected by a filter.
