04-03-2009, 08:43 AM   #1
alexeyga's Avatar
What's the overall length of the 50-135?
Just wondering if it will fit into my bag...
So what's the length of the lens with no hood attached?
04-03-2009, 09:48 AM   #2
Lloydy's Avatar
136mm according to the spec sheet.
04-03-2009, 11:28 AM   #3
alexeyga's Avatar
That's not much... just shy of 5 1/2".... Are you sure? On most pics it looks like a monster...
04-03-2009, 11:38 AM   #4
I don't have the lens anymore, but it is more then 5.5 inches. My guess would be closer to 8? Not quite as tall as the 200/2.8DA* but closing in on that size range. I just looked at the spec for the 200 and it is showing 134mm length, so I don't know what to say, hmm.
04-03-2009, 11:38 AM   #5
i think you must be looking at pictures of it with the hood attached. the hood is pretty big relative to the lens itself. compared to the 70-200s the 50-135 is pretty small
04-03-2009, 03:54 PM   #6
Lloydy's Avatar
Lens Mount: PENTAX KAF2 Mount Lens Construction: 18 elements in 14 groups
Angle of View: 31.5 - 11.9 degrees Aperture: F2.8
Aperture Control: Automatic Number of Diaphragm Blades: 9
Minimum Aperture: F22 Metering System: TTL open-aperture metering
Minimum Focusing Distance: 39.6 inches Filter Diameter: 67mm
Maximum Magnification: 0.17X Dimensions: 3.0" x 5.4" (76.5mm x 136mm)
Weight: 24.2 oz. (685g) without hood, 27.0 oz. (765g) with hood Case: S90-160
Objective Cap: O-LC67 Hood: PH-RBK 67mm
Lens Aperture Ring: N/A Tripod Adapter: No
Diaphragm Control: Fully Automatic Focal Length: 50-135mm (equiv. 75-203mm)
04-03-2009, 07:15 PM   #7
Andi Lo's Avatar
Question, can the 50-135 hood be stored / mounted in reverse when not in use?
04-03-2009, 08:36 PM   #8
Toshi's Avatar
QuoteOriginally posted by Andi Lo Quote
Yes, you can mount it in reverse for storage.
04-03-2009, 09:05 PM   #9
Hannican's Avatar
The lens is pretty large- it doesn't fit in my Lowepro SlingShot AW 200 mounted on the K10D, but I love it none-the-less, this thing is TACK sharp, and fast!
04-03-2009, 09:59 PM   #10
Venturi's Avatar
I just whipped mine out and measured it (sorry, couldn't pass that up). With the hood in storage position and both lens caps attached it measures 6.25" long by 3.75" wide. That 5.4" measurement must be how far it extends past the body when mounted.
04-03-2009, 10:48 PM   #11
QuoteOriginally posted by Venturi Quote
Agreed - from lens cap to rear cap I measure 15.7cm.
04-04-2009, 01:09 AM   #12
Toshi's Avatar
QuoteOriginally posted by alexeyga Quote
I see you list a 12-24 in your profile (assuming you still have it) - since I have both of the lenses, I took some side by side pics so you can see visually see the difference. *Note that I have a B+W filter on both lenses which increases length on both lenses by a few millimeters.
04-04-2009, 05:43 PM   #13
Canada_Rockies's Avatar
QuoteOriginally posted by Hannican Quote
You are not being creative enough. I get it into my 100AW on the camera. I manage to stuff into a 100AW (I was dumb - should have bought the 200, but ...) k10d with grip, 50-135, 16-50, 12-24, 100/4 M macro and 1.7X AF rear converter. The polarizer goes in the front pocket, along with a small blower brush and a card reader. I took out all but the largest L shaped divider.
k-mount, length, pentax lens, slr lens
Chinon 135 & Chinar 135 , Good Bad or Ugly seacapt Pentax SLR Lens Discussion 1 02-26-2010 09:03 PM
shoot out DA*50-135 v.s. A50 A*85 A100 A*135 Douglas_of_Sweden Pentax SLR Lens Discussion 42 12-11-2008 10:44 AM
All times are GMT -7. The time now is 04:49 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
