My photosniper outfit turned up in less than brilliant but quite usable condition. The lens looks rather batterd and is missing quite a bit of paint but it is fine mechanically (given that it it built like a tank I guess it would take a lot to do any serious damage). It had quite extensive fungus on most of the optical surfaces but this is not really supprising given its age. It was remagkably easy to dismantle the lens and clean up the optics and now it is spotless.
I had a look at the trigger and it turned out to be quite simple to ad a couple of switches to operate my DSLR. The trigger is now a 3 stage unit:
A gentle squeez engages the camera metering and the AF sensor - quite usefull for focus confirm,
Ther second and firmer squeez releases the pre set aperture allowing the lens to stop down as per the original,
The final squeez releases the shutter and takes the shot.
The modified trigger mechanism is shown in the last photo where the two added switches can be seen. The stock workes very effectively in supporting the lens and aiding accurate pointing, especially if you have some experience of rifle shooting.
I am very impressed with the image quality this old, simple 3 element lens achieves. It is remarkably sharp and contrasty (especially given the very simple coatings it has) and is a joy to use. The following are some of my first photos from the cleaned and modified photosniper setup.
User Photo Gallery - Nature User Photo Gallery - Nature
