04-06-2009, 09:36 PM   #1
Adaptall help for newcomer
Hello,
I recently got a Tamron lens that didn't come with any instructions. Can one of you veterans verify whether my PK Adaptall adapter is correctly installed on the 55BB?
The one wider than the other 'fingers' are fitted into the corresponding notches on the lens. The adapter is turned CW until the metal latch on the lens 'clicks' and pops out. The red dot on the adapter now lines up with the green dot on the lens.
One more thing. What does the black plastic button on the adapter do, as show towards the left side of pics 1+2.
Thanks in advance!
DiMAGE X20  Photo
DiMAGE X20  Photo
DiMAGE X20  Photo
04-06-2009, 10:57 PM   #2
IS050's Avatar
QuoteOriginally posted by boom Quote
Hello,
Thanks in advance!
I don't own a Tamron adaptall lens, but hope this would help.
https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/50712-please-e...daptall-3.html
David
04-06-2009, 10:59 PM   #3
ryan s's Avatar
I've only used that lens once (briefly) but I can speak in generalities.
Line up the green dot on the lens and green dot on the adapter, twist on, listen and feel for click, done! Both "fingers" should find a slot but it's been awhile since I've messed with this one.
The black lever is for locking the aperture into AE (aka A mode) on lenses with aperture rings. You have a PK-A version which allows this...worth a lot more than the normal PK version
04-07-2009, 03:57 AM   #4
Nesster's Avatar
here ya go
04-07-2009, 09:02 AM   #5
Otis Memorial Pentaxian
Nesster comes through! I can add that it helps if the lens is at its widest aperture setting with adapter off the "AE" position (not locked).
adaptall, adapter, dot, k-mount, lens, pentax lens, slr lens
Newcomer PGW Welcomes and Introductions 1 09-26-2010 08:01 PM
Hello from a newcomer from Auvergne-France alban Welcomes and Introductions 6 05-01-2010 12:58 AM
Newcomer from Spain. alvarossorio Welcomes and Introductions 6 04-10-2010 06:52 PM
k20 vs. k-x, vetern vs. newcomer suds Pentax DSLR Discussion 10 11-13-2009 05:21 AM
Newcomer jvanwees Welcomes and Introductions 5 02-24-2009 10:55 PM
All times are GMT -7. The time now is 06:43 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
