04-11-2007, 07:51 PM   #1
slip's Avatar
what type of metering does the K10...
When using a SMC M lens and the K10 (and K100 for that matter) do you have control over the light metering as far as spot, center, etc?
If not, which is the one that the K series uses with the M lenses?
thanks
randy
04-11-2007, 08:20 PM   #2
I believe it will only work as Center Average and Spot, but you can manually specify focal length which will make the Matrix metering work also.
04-12-2007, 05:04 AM   #3
RBellavance's Avatar
I don't know about the K100d, but on the K10D you can only use spot and center-weighted with SMC-M lenses. If you leave the metering selector on matrix, it will use center-weighted anyway.
04-12-2007, 09:05 AM   #4
QuoteOriginally posted by nystateofmind27 Quote
No, only centre weight and average, that camera needs to know more then just the focal length in order for the matrix to work, as the camera wouldn't be able to tell if it f1.4 on a dark day or f4 on a normal day, it has to have the min and max apperture
k-mount, pentax lens, slr lens
Machinery Type-R LeDave Photo Critique 6 09-26-2010 01:26 PM
Other A-Type Lenses? jeffshaddix Pentax SLR Lens Discussion 6 06-22-2010 06:36 AM
Nature what type hawk is this? airmechnorth Post Your Photos! 6 04-16-2010 09:00 PM
Machinery Type-R LeDave Photo Critique 3 09-30-2009 09:15 AM
A new type of poll! Adam Site Suggestions and Help 8 05-12-2007 08:58 PM
All times are GMT -7. The time now is 02:55 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
