Originally posted by Sudhakar Thanks Madhur
Thanks Hinman. Aluminium foil trick works for me (for AF part). I am fine there. It is more about stop down metering. There are some cases Av mode did not give me good results. For M42 lenses generally on my 100Dsuper, I need to use +2 EV to get good results; beyond this I can't adjust the dial further. In those cases, I will try to take stop down meter reading. Individually m42 lens works but when stacked with TC, I could not do. BTW, I use original pentax adapter ring only (for safer reasons :-))
--Sudhakar
I share mostly my m42 experience with K20D. I recalled my time with
Pentax K100D with certain M42 lens as in my first try on a
Pentacon 50mm f/1.8, I always seem to need to dial in +1.7 to +2.0 Ev compensation. That is just the lens alone and no TC is involved. I was thinking if I actually did it wrong before when I accidentally switched the A/M switch to 'A' instead of 'M' for manual diaphragm control. When A/M is on A for auto-mount diaphragm control, the lens aperture is wide open no matter what aperture you are in. I can't recall now as I don't have the set up to verify. Please check to be sure if your lens has the A/M switch or that it is a lens without the A/M switch and defaulted to Auto-mount. If my memory serves me correctly, I do run into consistent cases of +2.0 Ev adjustment in my K100D with m42 lens.
Also, when you have inaccurate metering, what happens if you switch to M mode and use the stop-down metering method. Do you hear the noise in closing down in diaphragm in small aperture as in f/16? And is the metering worse as in K100D, you don't have Ev compensation in M mode. That got changed in K20D and it is a big plus in K20D to be able to dial in Ev compensation in M mode. That feature was absent even in K10D but added in K20D.
From what I gathered, the metering with M42 lenses is best with K-7 and I hope those metering improvements also prevail in K-x and K-m. Someone who uses k-m can share their m42 experience.
Thanks,
Hin
