08-11-2011, 12:33 AM   #16
No pin in mine
Good Morning,
Great post and thanks for the tips on the conversion.
Mine arrived yesterday, a good looking Helios 44M-4 with screw mount.
After removing it from the packaging, I noticed the pin was missing, so I could not control the aperture blades.
Taking it apart as the instructions below, I manufactured a pin out of some solder (no I didn't solder the lens), just a little length with more wrapped around it to create the washer.
The aperture now opens and closes when the aperture ring is rotated, but every now and then it closes when trying to fully open the iris. I have also held down the rocker switch with my little finger and after a few opens and closes it does the same.
Also, It stops stepping down at 11 and will only open to 2,8. I can live with this as it only cost £8 + shipping, the lenses are in perfect condition along with the body.
My reason for posting is to ask if anyone else has encountered the above, or is it something to be expected because of the way the lens has been manipulated with the conversion.
Thanks for any assistance in advance.
12-08-2011, 11:35 AM   #17
Same problem here: https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/167906-helios-...g-trouble.html
..I used a piece of plastic tube from a ball pen (measure the length by sticking it on the pin to begin with). It works very well, thanks.
04-15-2012, 06:34 PM   #18
JFD
Managed to pick up a minty version of this (not even any internal dust that I can see) while in the UK at a charity shop for 5 pounds. Just did the mod using the cotton bud stick. Works brilliantly Thanks.
12-07-2012, 12:22 PM   #19
enemix's Avatar
I also got a 44M-4 and this thread was great help! Just gave it a cotton stick implant (took less than 5 min) and now it's fully manual, thank you guys!
12-29-2012, 06:03 PM   #20
Just got one and haven't been able to unscrew it. What type of screwdrivers do you use? I've tried a small one from the obstetrician but it easily bent the whole screw driver when I tried removing them.
12-29-2012, 07:14 PM   #21
tromboads's Avatar
bent the screw driver??? wtf indeed! If everything is jammed that much get some WD40 etc etc into those screw threads.
*Hearts my Helios
12-31-2012, 08:15 AM   #22
QuoteOriginally posted by Cramchri Quote
Your obstetrician* uses a screwdriver? Not good...
*= women's health doctor
Oh...BTW...Welcome to the Pentax Forums! Sorry about your problems with the Helios.
01-01-2013, 10:22 AM   #23
enemix's Avatar
Probably to fix Anne Droid?
aperture, aperture control, change, cover, k-mount, lens, note, orientation, pentax lens, pin, silver, slr lens
Helios 44M figmental1978 Pentax SLR Lens Discussion 32 10-30-2013 08:25 PM
Sibling Rivalry: Helios 44M vs. Helios 44M-4 stevebrot Pentax SLR Lens Discussion 36 08-03-2013 09:31 AM
manual focus, auto aperture 55? Impartial Pentax SLR Lens Discussion 4 10-12-2010 05:36 PM
DA* 55mm vs Helios 44M yusuf Pentax SLR Lens Discussion 13 08-21-2010 05:06 PM
Helios-44M revisited... Rense Pentax SLR Lens Discussion 41 04-17-2010 09:42 PM
All times are GMT -7. The time now is 10:12 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
