Looking at the lens I have (S-M-C Tak 50/1.4) I still can't quite figure out how your lens came apart.
Anyway, in order to see what's going on, you will need to take off the name/trim ring like I said before. Make sure the filter threads are dirt-free and have no dents. Use a friction tool that can grip the ring without touching the front element. A screw-mount rear cap is the right diameter, but it needs to have a rubber grippy surface where it touches the trim ring. People have used crutch tips, rubber stoppers or chair leg protectors too. When you get that off, remove the three small screws holding the filter ring on. My lens looks like this with the filter ring removed:
http://picasaweb.google.com/lh/photo/KKOf-A1--zUhE3JTMgKEzg?feat=directlink
The green arrows point to where the filter ring screws attached. The red arrows point to screws holding the focus ring to the brass ring. This brass ring has threads on the inside for the focusing helix (large aluminum threads in your photo) and outside fine-pitch threads that screw into the barrel. As far as I can tell, the inside threads were unscrewed too far. On my lens, two stops prevent that from happening. The focus ring has a notch in it that engages a stop screw in the lens barrel. The screw is marked here with a green arrow:
http://picasaweb.google.com/lh/photo/yJJgTsr4-oGbODb3zj7MPg?feat=directlink
Green arrows here mark the ends of the notch:
http://picasaweb.google.com/lh/photo/D6crj-sqjybWLCDNxNwwOw?feat=directlink
Also I can't unscrew the brass ring beyond a certain point. There must be another stop I can't see, and I'm not going to try that hard to find it either.
Your lens is different; maybe the second stop is a newer feature.
I would proceed like this: take off the three screws holding the focus ring to the brass ring and remove the focus ring. Look for the focus stop screw like my photo shows. If it is missing or sheared off, you should replace it so that stop works.* Unscrew the brass ring so that it projects as far forward from the lens barrel as possible while still having its threads engaged, or at its internal stop if your lens has one.
You may be able to rethread the focus helix back onto the lens body now. These threads usually have multiple entry points and only one is correct. The only one I've taken apart had three starting points, 120º apart. I tried all of them and used the one that got the lens to go back together the best. Just set the helix on the brass ring and turn the ring. Remember to reset the brass ring before each new attempt.
If you manage to get everything together you'll have to reset infinity focus upon reassembly.
*The stop screw is half-obscured by the DOF scale ring. Three tiny grub screws hold this ring on. If you remove it, be careful that the aperture ring doesn't slide off too. A 2mm ball bearing is trapped between the aperture ring and the barrel, and it's easy to lose.
Reason: add direct links to photos in case embedding fails
