Originally posted by Just1MoreDave Can you tell me this secret surgery? I have been using my Vivitar 300/5.5 with the T4->M42 adapter, but I have the TX->K also.
Hey Dave,
Unfortunately, I can't take and post photos now. But let me try to explain....
There is no such thing as T4->PK adapter. Why not? Because T4 mount does not have a way to communicate the setting of the aperture ring to the camera body. This prevents T4 lenses from having full-aperture metering, which is required by PK mount.
TX added this capability. It has an additional pin on the adapter. This pin is captured in a prong of the TX mount. The prong moves with the lens's aperture ring. Inside the adapter, the pin is connected to a lever. This lever is the coupling that tells the body the setting of the aperture ring.
If you look straight at a Pentax
film camera's lens mount, there is a lever at 1:30 o'clock position, moving between 1:30 and 4 o'clock, telling the camera the aperture setting of the lens. Pentax DSLRs do not have this lever thus can not do full-aperture metering with manual lenses; you need the green button for a close-down metering.
The problem of adding the pin to the TX adapter is that there is no place for the pin to go in a T4 mount. You end up either (1) using the T4 lens at full aperture (the pin makes the aperture ring getting stuck) or (2) not being able to set the aperture ring at max aperture (the pin blocks this position inside the adapter).
Now that you know why TX adapter doesn't work in a T4 mount, the solution is simple: remove that pin.
This is what I did on my TX->PK adapter: undo the 4 screws that hold the 2 halves of the adapter shell together, then dump out whatever mechanism between the two halves of the shell out into a ziplock bag, stick a note in the zip lock back indicating that the contents are from a TX->PK adapter, put two parts of the shell together, install the 4 screws.
That's it.
Note that this surgery will make the TX lens
not metered correctly with a film body. The body always thinks the lens is set at max aperture (or min aperture, I don't remember).
Give it a try and post back if you have any problem.
Good luck.
