Originally posted by Jewelltrail Daniel:
This truly is fantastic work! It is such a joy to see you cultivating your BIF shooting utilizing decades-old technology--this is where the art still is in photography. I am impressed, but you had better not give away too many secrets or the sales in newer lenses might start dropping off.
All my lenses are AF except Zenitar (for zone focus) and this A300mmF4. And my new one is a DA200mm
Quote:
Perhaps someday I'll gather up the courage to attempt something like this, but I'll be sure to prepare myself for failed results before I begin. Best.
Hey failure only results in you making a click to erase it. Big deal.
Simple speed Test for MF focus skill
All my BIF images starts off at subject around 100 ft away.
Pick a fixed subject 100 ft away. On a bright day set 1/1000s, F8, iso 800. Also set the manual distance dial to 120 ft , raise up your camera and fire in burst right away. Of course you will get bland image OOF. Quickly turn your focus ring (anticlockwise for A300mm) until you can see your image focused in the viewfinder. I believe it will take a new fellow 2-3 seconds to focus.
The above is just a workout/stretching
After practicing MF on the fly on fixed subject , repeat the same process on a slower moving subject.
You will be the king of MF if you can do BIF image of a sparrow, chickadee or cardinal (or similar size bird). The best I have done so far is a slightly OOF image of a cardinal.
That will be interesting exercise costing nothing at all
Daniel
